R60 +1 tire size
+1 tire size
Has anyone installed +1 tires on their 2013 Countyman S? My car is running the stock 17" rims and the 205-55r17 tires, and I'm looking to put on 225-50r17's. They will be 0.1" taller, but will be 0.7" wider. The new tires will fit the stock rim width. My main reason for the change is to open up more run flat tire options. I have been using the oem brand and style for about 4 sets now and wanted to try a different brand that has comparable wear rating and better handling. I have a tire in mind but wanted to see if there is a mounting / rub issue anyone has run into.
Regards,
Trp19string
Regards,
Trp19string
trp19string (12-13-2021)
From my experience, I did put 225/50 r17 on my OEM Double Spoke Wheels (7x17 et 50) from my 2011 CMS. these were just fine
If you go to 225/55, There are 2 weld tabs in the rear weld arches (one on each side) that you need to worry about. These poke out just enough to rub the inside of the tires sidewall when you are turning at regular speeds. At low speeds its fine put when exiting and entering the motorways you will rub.
cravetheMINI
Tires, Wheels, & Brakes
04-09-2013 02:39 PM
