R60 2015 burning (not leaking) oil, where to start looking?
My wife's 2015 all4S with around 100k which is using oil. The last time I checked it needed a quart after 1k miles of driving. There isn't a drop of oil on the ground, and I had her start the car cold the other day and saw the puff of oil burning off as it started. I had her floor it as she was leaving and saw the smoke coming out of the exhaust under hard acceleration. This isn't billowing smoke, but noticeable if you are looking for it.
We have just been adding oil for a while but since its using more now I feel like should get around to fixing it. A while ago when I first noticed this I changed the pcv out for a new one I had one of the intake tubes from the turbo off to check and I did see some oil sitting inside the pipe.
I think oil is leaking into the air intake tract somewhere and burning off, am I missing another explanation? Assuming I'm looking in the right direction what are the trouble spots on these cars that commonly fail? How can I diagnose where it is coming from?
Thanks!
Thanks!
Hello,
Its either the valve cover or the valve stem seals. If its the valve cover that has been fixed already, its those valve stem seals.
https://www.ecstuning.com/Mini-2015-...Engine/Covers/
https://www.ecstuning.com/Mini-2015-...d/Valve_Seals/
11340033950
https://www.northamericanmotoring.co...-camshaft.html
11340033950
jawilli6 (07-30-2024)
I did not replace the entire valve cover, just the rubber diaphragm and plastic cover/spring on the upper left part of the valve cover. Is there a chance that something else failed or i installed this incorrectly so it’s causing the oil consumption?
also is there a chance the turbo is causing the oil leak into the engine?
The consumption feels like a lot and like it happened relatively suddenly for it to be burning as much is it is through the valve stem seals but I could be totally off base.
thanks!
thanks!
And if that's the case the back side of the valves are all sludged up.
2014 MC (07-30-2024)
https://www.ecstuning.com/b-bremmen-...MaAuqcEALw_wcB
I used this one:
Bremmen Parts - 11127646552 - Valve Cover With PCV - N18 Engine (ecstuning.com)
My understanding is these engines do use some oil. I think it's even in the user manual to check the oil and top up as needed every x number of times you fuel up with gasoline.
Yup, it's in the 2013 R60 manual:
I used this one:
I was able to get them on/off without removing the fuel line. Easier to get off than on. If it doesn't come off relatively easy and you start having to flex the part to get it around the fuel line, I'd probably stop and remove the fuel line. I wouldn't want to dislodge an o-ring/gasket from flexing it and not know it. I actually didn't think about that at the time and maybe that's why I had to do it twice?
I don't recall the torque spec and order. I know I downloaded it after paying bmw TIS system for it, I'll have to check my home computer and I'll post it here (assuming that is allowed). The torque will be specified in newton-meter in case you beat me to it.
Puffs of smoke after engine has been sitting a while sounds like valve stem seals.
You can eliminate turbo seals by looking at the exhaust side with a borescope through the oxygen sensor hole. But blown turbo seals would be smoking oil all the time, not just a puff on start up, so I'm still leaning to valve stem seals.
RCRacer
R60/R61 Stock Problems/Issues
03-23-2019 08:20 PM
