2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Carplay finally!
Old 01-29-2021, 06:15 PM
Matthew Dufresne's Avatar
Matthew Dufresne
Matthew Dufresne is offline
Hi there,
I have a 2018 F54 Clubman with 6.5" Touchscreen and Nav. Can I get some help with Carplay?
VIN: 2C42369
Thanks!
  #177
Old 01-30-2021, 01:50 PM
Matthew Dufresne
@sb2002 , do you know if carplay will work with my Clubman?
  #178
Old 01-30-2021, 02:24 PM
sb2002's Avatar
sb2002
sb2002 is offline
PM’d.
  #179
Old 03-01-2021, 08:27 PM
Milkbottle's Avatar
Milkbottle
Milkbottle is offline
Hi sb2002, do you think you will have the time to assist me in adding Apple carplay to our Mini countryman?
  #180
Old 03-02-2021, 06:53 PM
sb2002's Avatar
sb2002
sb2002 is offline
Hi Milkbottle. Will you post your vin? You’ll need to post once or twice before we can pm.
  #181
Old 03-02-2021, 10:38 PM
Milkbottle's Avatar
Milkbottle
Hi! My VIN is WMWYT920703E17903
  #182
Old 03-03-2021, 08:48 PM
Milkbottle's Avatar
Milkbottle
Morning sb2002, still haven't received a PM yet.
  #183
Old 03-04-2021, 03:22 AM
sb2002's Avatar
sb2002
sb2002 is offline
PMd.
  #184
Old 03-04-2021, 08:01 PM
thenadz's Avatar
thenadz
thenadz is offline
2018 f56
Hi there,
So glad I found this thread as I was purchasing my 2018 MINI F56 this week. I am hopeful I can get Apple CarPlay either by replacing the head unit or maybe through a software upgrade. Don’t have touchscreen but I do have Nav.
VIN: 2G61661
Help is appreciated!
  #185
Old 03-07-2021, 08:34 AM
Milkbottle's Avatar
Milkbottle
Just found out I need to have the head unit replaced to the NBT-EVO version along with the large 8.8 screen :( Has anyone ever just replacing the head unit and leaving the 6.5 touch screen instead of swapping that out as well? would it work? as it would reduce the cost in parts dramatically lol
  #186
Old 03-22-2021, 06:38 AM
erdem's Avatar
erdem
erdem is offline
PM’d.
Dear @sb2002,
I am Erdem from Istanbul-Turkey. I have 2019 Mini Countryman with small touch screen without nav. Is it possible to activate apple car play in my car? I tried to pm you but failed. I can share my vin if you need that detail.
Thanx in advance,
Erdem
  #187
Old 03-22-2021, 06:48 AM
Jason Martin's Avatar
Jason Martin
Jason Martin is offline
Carplay is possible!
Erdem
you have reached out the person that can facilitate this for you@sb2002.
Apple CarPlay
Mini Connected menu
Google Maps
iTunes
I have the same set in my vehicle and i was able to get carplay and sirius Xm with spending a ton of money or buying the mmi module or some cheap chinese module. Sb2002. & Ndal with get you up and running you just beed to verify if you have the wifi antenna port on your receiver behind your dash.
Originally Posted by erdem
Dear @sb2002,
Thanx in advance,
Erdem
  #188
Old 03-22-2021, 06:55 AM
MasAyinde's Avatar
MasAyinde
MasAyinde is offline
Has anyone been able to upgrade to the 2022 UI and get Carplay working?
Jason Martin (03-22-2021)
  #189
Old 03-22-2021, 06:59 AM
Jason Martin
Erdem
he will need the last 7 of your vin he has probably read this read this thread and will be in contact with you.
jason
  #190
Old 03-22-2021, 07:01 AM
Jason Martin
Mas Ayinde
i am waiting for my entrynav2 which i was able to get through SB2002 and once i receive i will be updating. I know its capable and working. I will post pictures up as soon as NDal is dine with his part.
jason
  #191
Old 03-22-2021, 05:24 PM
sb2002's Avatar
sb2002
sb2002 is offline
Dear @sb2002,
Thanx in advance,
Erdem
Hi Erdem. Would you share your vin? If you post once more, we’ll be able to pm.
  #192
Old 03-22-2021, 05:25 PM
sb2002's Avatar
sb2002
sb2002 is offline
PMd
  #193
Old 03-22-2021, 09:09 PM
Jason Martin
I just did a few weeks back I purchased the 8.8" from @sb2002 and @ndal handle the coding for me. I just received my enaventry2 and I will have my system updated and coded for full screen carplay and move my sirius subscription to this vehicle. It was plug n play. You need to have it coded to your vehicle. Get with SB2002 he will take care of you. Here are some pics.
Apple CarPlay on 6.5" screen
Apple carplay on 8.8" screen.
  #194
Old 03-23-2021, 12:34 AM
erdem's Avatar
erdem
erdem is offline
Hello,
Last 7 digits of my vin is 3L00316
Thank you.
  #195
Old 03-23-2021, 05:08 PM
sb2002's Avatar
sb2002
sb2002 is offline
Hello,
Thank you.
PM’d.
  #196
Old 03-26-2021, 08:51 PM
Aphex's Avatar
Aphex
Aphex is offline
Hi sb2002! I'm looking at purchasing a 2020 Countryman S with the 6.5" screen. Is there a way to confirm if this one can be coded? Last 7 of the VIN is 3L92828
Please let me know, Thanks!!
  #197
Old 03-27-2021, 12:06 AM
Milkbottle's Avatar
Milkbottle
Morning everyone! I thought I would share a little update with you, So after doing some more research and despite having a few red herons thrown in, we were able to activate carplay in a late 2017 mini countryman. Here are my car specifications to show you.
Car built Nov 2017
EntryNav2 head unit installed + has a port on the head unit to install an antenna
6.5 touch screen
EntryNav2 head unit port connections - quite easy to gain access too.
Wifi port located in the red circle
You can download the E-sys program and using an obd2 cable to ethernet cable connect to your can and check the FSC section to see if you have the APPID 323 (0x143) if you do you can have this activated using an FSC code.
APPID in the FSC section on E-SYS
Wifi Antenna is installed + FSC code + removed all saved phones from the car - Paired a new phone Carplay up and running
I would like to thank everyone who assisted me on this little adventure
Now on to the next project - OEM retro fit front parking sensors to the car :D
  #198
Old 03-27-2021, 04:18 AM
sb2002's Avatar
sb2002
sb2002 is offline
PM’d.
  #199
Old 03-27-2021, 11:50 AM
newtomeeni's Avatar
newtomeeni
newtomeeni is offline
Apple CarPlay Activation 2018 Cooper Countryman
PM’d.
Hello,
I would also greatly appreciate some instructions or help on how to activate Apple CarPlay in my 2018 Mini Cooper Countryman S All4. I have nearly no car knowledge and am finding this thread a little confusing as I have just purchased my first ever Mini.
Thanks in advance!
  #200
Old 03-27-2021, 01:18 PM
sb2002's Avatar
sb2002
sb2002 is offline
Originally Posted by newtomeeni
Hello,
Thanks in advance!
Hi. We’ll need your vin to know what’s possible. If you aren’t comfortable posting it here, I think if you post once more, you’ll be able to pm me.
Quick Reply: F60 Carplay finally!
