2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Has anyone lifted there F60
Old 07-27-2019, 07:20 AM
09BMW328's Avatar
09BMW328
09BMW328 is offline
Starting to research this and seems M7tuning makes a 2.5 lift kit and it looks awesome. If anyone has done this or thinking let’s look at some pros and cons . Handling, Awd axle vibrations ?? , etc etc . Tire and wheel sizes etc .
https://www.m7tuning.com/lift-kit-f6...x1-mini-cooper
APMini (07-06-2021)
Old 07-27-2019, 01:27 PM
d2mini's Avatar
d2mini
d2mini is offline
I've seen that kit.
My question is how does one handle changes in tire circumference. In the Jeep world, we have OBDII tools that will let you set the tire diameter in the Jeep's on-board computer so your speedo and everything reads correctly.
Old 07-28-2019, 06:31 AM
sbreech's Avatar
sbreech
sbreech is offline
Originally Posted by d2mini
I've seen that kit.
I’m not so sure that any Mini speedo is ever correct. 🤣. We own 3, all with factory size wheels and tires, and they are all off my 2 to 4 mph, including my 2019 with only 300 miles.
Ian156 (06-05-2023)
Old 08-01-2019, 06:57 AM
BDI's Avatar
BDI
BDI is offline
Had no idea that this kit finally came out. I was able to fit oversized A/T tires without the lift. I kinda like the look without the lift at the moment.
However, I would love to see a lifted Clubman with some oversized tires.
Old 08-05-2019, 06:20 PM
Madman23's Avatar
Madman23
Madman23 is offline
What size and type tires did you go with? Did you use spacers? PICS!!!!! Please
Old 08-08-2019, 05:58 AM
BDI's Avatar
BDI
BDI is offline
225/65r17 BFGoodrich All-Terrain T/A K02
I should have went with spacers but ended up modded the inner fender liner because it would rub on full lock.
The following 4 users liked this post by BDI:
APMini (07-06-2021), CJC (12-04-2019), Ian156 (06-05-2023), MOMERR80 (04-21-2022)
Old 08-08-2019, 06:08 AM
09BMW328's Avatar
09BMW328
09BMW328 is offline
That looks awesome . did you do the lift or just tire upgrade . also is yours a stick/auto any wobble felt from the axles etc
Old 08-08-2019, 07:14 AM
BDI's Avatar
BDI
BDI is offline
Thanks!! I just did tire upgrade. Auto transmission, no wobble at all.
Old 08-13-2019, 09:50 AM
09BMW328's Avatar
09BMW328
09BMW328 is offline
Bdi what exact wheels are those and your offset
Old 12-04-2019, 09:02 AM
CJC's Avatar
CJC
CJC is offline
BDI,
What wheels and offset did you use?
I'm going to put these same wheels but was waiting until I could purchase the M7 Speed Gen3 2.5" lift. However, now that I've seen yours I think I can do the tires/wheels now and lift later. I was hoping to use a 17x8 5x112 with a +32 or +35 offset. I will mostly likely use spacers instead of fender or wheel well mods.
Old 12-04-2019, 09:59 AM
CJC's Avatar
CJC
CJC is offline
09BMW328,
I plan on putting the M7 Gen3 2.5" lift on my 2018 Mini Countryman S All4 next year. I am probably going to do the BFG AT KO2s with spacers in the meantime after seeing BDIs post with his KO2s on his 2018 Mini CMS All4
Old 12-05-2019, 08:30 AM
ECSTuning is online now
Received 2,097 Likes on 1,871 Posts
Here are some examples of the F60 lifted kits, wheels and tires. https://www.brittle.co.uk/listing/co...automatic-f60/
MINI #2
MINI #3
M7 Speed 2 1/2" lift kit, 225-65x17 All Terrain tires and other cool add-on accessories.
Its on sale right now also:
https://www.ecstuning.com/b-m7-speed...70-530200~m7s/
Some more info
https://blog.ecstuning.com/m7-speed-...an-countryman/
Old 12-09-2019, 02:26 PM
MiniAdv's Avatar
MiniAdv
MiniAdv is offline
I installed Journey's Offroad 2" lift kit. It is half the price of M7 kit at $550.
https://www.journeysoffroad.com/mini...-lift-kit.html
The 2" kit did not require removing the half shafts, but needed a big bar and a lift to install. Another half inch would have required taking everything apart as you'll see in the M7 installation instructions.
Also, I installed Blizzaks for winter using the stock rims (Size is 225/60/18). They are 28.6" tall, nearly 2" taller than stock. No rub, but very tight. This is my new winter set-up.
I will add new All Terrain tires with new 17" wheels in spring.
The following 3 users liked this post by MiniAdv:
Ian156 (06-05-2023), OverRev (01-09-2022), SunBird (12-30-2019)
Old 12-09-2019, 02:33 PM
MiniAdv's Avatar
MiniAdv
MiniAdv is offline
Amazingly, my larger diameter tires (225/60/18) fixed the incorrect speedo reading of my 2018 S All4. Was off by 3-4 mph at 70 mph. Now its dead-on.
Old 12-09-2019, 02:34 PM
MiniAdv's Avatar
MiniAdv
MiniAdv is offline
I also added 15mm wheel spacers.
Old 12-11-2019, 12:35 PM
Which brand spacers?
Old 12-11-2019, 07:02 PM
chrisreese's Avatar
chrisreese
chrisreese is offline
How hard was the lift kit install? Did you do it yourself? I checked out the link and the price is great but I didn't see any installation instructions.
Old 12-15-2019, 07:30 PM
MiniAdv's Avatar
MiniAdv
MiniAdv is offline
Originally Posted by ecstuning
which brand spacers?
ecs!
ECSTuning (12-16-2019)
Old 12-15-2019, 07:36 PM
MiniAdv's Avatar
MiniAdv
MiniAdv is offline
My buddy has a wheel shop and did the install with my help (ha). Its not for the wannabe mechanic. We confirmed what we were doing against the instructions on M7's site. Same everything except was able to leave half shafts in.
Old 12-29-2019, 08:01 PM
Madman23's Avatar
Madman23
Madman23 is offline
Has anyone on here lifted a manual F60? I only ask because I have already had transmission issues.
Old 12-30-2019, 09:04 AM
Clutch or actual internal issues? If its the clutch that can be from the way you drive, drive more aggressive and the clutch on these cars can burn up faster, that why if you mod we recommend a performance clutch to hold the power. Lifting the MINI adds a little weight, most weight added to the drivetrain comes from heavy nubby tires and heavy wheels.
Old 12-30-2019, 06:25 PM
Madman23's Avatar
Madman23
Madman23 is offline
First one was a faulty throwout bearing. Second was misalignment causing a suncro to fail. I was told not to drive it like my M3 (180000 miles) and my E30 (364000 miles).
Old 12-31-2019, 06:02 AM
Yep, have not heard anything like that on the new F60, throw out bearing wear is usually way down the road ( usually 100k), I have seen it many times on the older Gen 1 cars. Have not heard about the syncro. Those gen 3 transmissions should not have that many problems. I have autocross my older MINIs and they have a less refined getrag (earlier version) manual transmission
Thanks for the info.
Old 05-29-2020, 08:52 AM
PDXLAPIS's Avatar
PDXLAPIS
PDXLAPIS is offline
MiniAdv,
Did you end up getting rims/ATs? if so, what did you go with? Thanks!
Old 05-29-2020, 09:09 AM
09BMW328's Avatar
09BMW328
09BMW328 is offline
i NEVER LIFTED THE CAR AS I SOLD IT A FEW MONTHS AGO. However I still have wheels and tires for sale if your interested they are in the FOR SALE FORUM
PDXLAPIS (05-29-2020)
Quick Reply: F60 Has anyone lifted there F60
