F60 MINI Roof Box - Pic Request
Anyone have the MINI brand Roof Box?
https://www.shopminiusa.com/PRODUCT/1092/MINI-ROOF-BOX
Any pics? Feedback? Reviews?
I bought the roof rails and roof box from Mini a couple months after buying the Countryman. I figured I would need it for longer road trips with lots of stuff packed up. I've had it on the car 3 or 4 times so far and it has worked nicely. It did not bring down my gas mileage very much either, maybe 2-3 mpg reduction was all. You can feel the weight up there a little bit in corners, but it never felt like too much. After you install it once the process is pretty easy. I would recommend it for sure.
I picked one up.
Installed it today.
It's a bit tall - I kind of prefer the lower profile wider boxes but it will do... we plan on keeping it on the car all the time as it's too big to really store anywhere when not in use.
My wife drove the car today and said she could feel it being pushed around a bit more in the rain but wasn't bad.
Pics...
Installed it today.
Pics...
seamonkey420 (08-15-2020)
funny thing was i was wondering the same as i'm looking into a roof box. found some base cross bars for about $100 that look to match. so anyone know if the 2020 F60s roof racks are same as 2019? also i'll post some roof boxes i'm looking at once i find a few. planning to make my clyde a more rally styled countryman since i'm at my mom's farm a ton more and on gravel a ton. also.. All4 on gravel.. a blast!
looks good.
the box leaves good room on the rails, fits skis. It looks like it’s sitting a little forward on the car. Not sure where the lift gate swings to but most boxes seem to have the front line up with the windshield, so about 4-5” back? I’m not in Aerodynamics but might be the feeling since it’s forcing the air under the box and deflecting off the windshield
Your garage set up is fantastic.
How was adding the OEM mud flaps? I cracked 3 of the 4 OEM mud flaps and intend on replacing them once I get a lift.
looks fantastic, definitely looks centered. Hopefully it improves the drive. It’s a fantastic looking ride. We are in the market for a new car soon and this would fit the bill perfectly.
I had no issues. The flaps themselves are just like any other I've used. How did you crack them? They are quite pliable, but you don't need to bend or twist them? The screws or clips don't put enough torque or pressure on them that they would crack, but even with full force they shouldn't crack, if anything they'd just compress. I didn't even lift the car up to install them. Did it with the car on the ground.
Just drew a line over an image I found on google. Red line is where it split. Might be able to put some epoxy--forgot how bad it actually was, but I remember some small sections missing.
Been taking the F60 "off-road"-ish these last few months and it's been OK for the most part. They cracked when driving over some rocks I guess. Mud flap probably came down directly onto a rock as I drove over it. Broke along this seam for I think 2 of them. And lost a section of one of the flaps.
offloading! Like it!
I see that you installed directly over the factory-indicated install points, and it looks funny at the front, and the one I saw at my MINI dealership totally ignored the designated mounting points (which are only 26" apart), and went considerable wider (bar spacing) and further back as well. Does any of it matter? Hmmm...
Oh...I was premature. I see you came to the same conclusion. :-)
VagabondSteve
08-15-2017 06:31 AM
JT///MC
06-27-2013 04:56 AM
