F60 Front Camber Adjustment (Currently Stock)
As I understand it, there is no built in camber adjustment on the F60s. My suspension is totally stock, and the front right tire wears unevenly on the outside 1.5” or so. I’m wanting to adjust the camber slightly to the negative to correct this. Is there a camber plate that works with the rest of the stock system? Do I definitely just have a bent arm or something? I’ve not hit anything, but someone else owned it a year before I did so it’s possible.
Appreciate any guidance you have! Thanks.
Kmac has them.
https://www.ecstuning.com/Mini-2019-...n/Camber_Kits/
I would have it looked at first to see if anything is bent or damaged and then go from there at an alignment shop.
eric.stewart (07-09-2024)
Matt Clark (08-30-2024)
fozworth
Suspension
26
03-01-2007 06:44 AM
SMF (Street Modified FWD) Why and how to add camber plates for Auto-X?
minihune
SCCA Solo and ProSolo
14
07-18-2004 06:09 PM
