Bimmercode App
#251
That's part of the issue I have. The previous coding that was done to get the UJ lights working was with the old phone. We thought everything was good but did not think to drive it to test that no errors set while the car was in motion. Since the lights operated ok, we left them in for the week until we could mess with the coding again... in that week, a new phone was delivered and the old one wiped clean and shipped off. So the oldest saved backup should in theory be the last code that got the UJ lights working but with the error when braking. Codemycar tried getting the UJ working after I couldn't figure it out originally, but we ran out of time to test things since the usual program code he uses didn't work for this car. He said he can flash it back to stock so we should at least be good after that... then I'll make sure to save and export a copy of the stock code before we mess with it again.
#253
JCW Tach and Gear Selection in HUD
HU_NBT > EXPERT MODE > HUD_SPORTANZEIGE_ENABLE, HUD_SPORTANZEIGE_FES_ENABLE, and HUD_SPORTANZEIGE_MS_GASSE_ENABLE to AKTIV.
Code
Then:
KOMBI > EXPERT MODE > FZG_Aussttang,HUD _SPORTANZEIGE_ENABLE, HUD_SPORTANZEIGE_FES_ENABLE, and HUD_SPORTANZEIGE_MS_GASSE_ENABLE to AKTIV.
Code
Did you go into the HUD settings on your center display and select the tach "ON" after coding it? I also remember I had to cycle the ignition twice to get rid of the error message.
Cheers!
-Joseph
The following 2 users liked this post by JosephM635:
BamaMan44 (02-09-2020),
José Manuel Pino (07-03-2019)
#254
#256
Code
Then:
Code
Cheers!
-Joseph
Code
Then:
Code
Cheers!
-Joseph
Hi. If the JCW Tach checkbox (Sport Displays I think is called) is ON in the HUD settings of iDrive.... and you use the NAV nothing NAV related is shown on the HUD. You can change Multimedia things, make calls, etc and all that appears on the HUD.... but nothing related to Navigation.
To have the arrows, directions etc shown you have to untick the Sports Display checkbox.
Is there a way (which btw should be the default..not the nonsense mess BMW has done) to keep the JCW Tach always displaying and NAV related things appearing as needed (like multimedia, phone, car messages, etc) ??
Thanks!
#257
No one, to my knowledge, has found a way to have both in the HUD at the same time. Or having it switch back and forth as needed. Without doing it manually.
Cheers!
-Joseph
emulajavi (07-14-2019)
The following 2 users liked this post by bluonyx:
Fahfoofnik (07-26-2019),
Walt (08-07-2019)
#259
#260
It's been talked about in this thread above, but it is a simple matter of changing the output:
Rear Fogs as Brake Lights:
BDC_BODY
3065 LceLampMapping4, ED
Funktionen
MAPPING_BREMSL_2_L_OUTPUT
Switch to this
nsl_l (this is the rear fog light choice)
You need to do this for right and left. Above is for left,
For RHS just change the l to r
MAPPING_BREMSL_2_R_OUTPUT
nsl_r__________________
BDC_BODY
Funktionen
Switch to this
My F56 has only a single rear fog light, located in the center of the lower rear bumper (my exhaust is off to the left).
Do I still do both _l and _r (its a single assembly, but has a left half and a right half)?
Do I only do the _l?
Do I only the _r?
Do _c for Center?
#262
Regarding Rear Fogs as Brakelights:
Great, I got the opposite problem of some folks - I activated the rear fogs, cycled the ignition, then coded the fogs to act with brake lights, and only got the TOP of the main brake lights to work, instead of just the bottom like others experienced. I have a 2016 Mini Cooper S, 4-door hardtop.
#264
#266
https://www.minif56.com/threads/club...-coding.74850/
Walt (08-17-2019)
#267
#272
This recently happened to me when I went in and enabled daytime running lights in the rear. Those never happened apparently and I just got blank upper rear lights. Took the coding back out and now have the full rear brake lights and fogs as brake lights.
#273
BDC_BODY
Funktionen
Switch to this
#274
#275
I’m struggling with the JCW HUD one, I thought I’d coded it but maybe some mistakes.
I’ve got the new 3 options in the hud menu but when I try to tick these options only the two sub-box, "S shift" and "sport mode" ticks but nothing appears in the hud.
I noticed the speed in HUD would shift to left for a while when I start the engine, but it will go back to the center after 3 or 4 seconds. nothing changes.
Any thoughts guys,thanks for the help 👍
