Bimmercode App
#376
I did the BL and BFD mapping for 1 and 2 respectively, and it caused the 8041C3 code mentioned above. This is the exact reason why I reverted back to the defaults. Again I do believe BL and BFD are the right values but the computer thinks the mapping is not appropriate at least on UJ light for USA version.
#377
And you set
Both Left and Right
as
BFD_x_KALTUEBERWACHUNG - nicht_aktiv
BFD_x_WARMUEBERWACHUNG - nicht_aktiv
BFD_x_IS_LED - aktiv
BL_x_KALTUEBERWACHUNG - nicht_aktiv
BL_x_WARMUEBERWACHUNG - nicht_aktiv
BL_x_IS_LED - aktiv
FRA h _x_KALTUEBERWACHUNG - nicht_aktiv
FRA h _x_WARMUEBERWACHUNG - nicht_aktiv
FRA h _x_IS_LED - aktiv
Both Left and Right
as
BL_x_IS_LED - aktiv
#378
And you set
Both Left and Right
as
BL_x_IS_LED - aktiv
Both Left and Right
as
BL_x_IS_LED - aktiv
#380
Again I trust it works but does not mean the computer is not storing a code. This is 100% true when you code BFD on UJ light for USA cars. My post above is to help folks understand this and see if someone has solved it.
#382
No, the code I shared is when you set blinkend and map to bl and bfd per the instructions posted here. I shared the defaults and clearly it was area enlargement. Since I don't think you have UJ light and seen the code, I can understand it is hard for you to understand.
#383
Question for the group here. I currently have a 2023 Cooper SE on order and it should be arriving in month or so. The car will come with the Mini LED headlights as I understand. My VO currently include the 8S4 "Variable Light Decoding" option on the build. I have been researching to see if anyone has had luck with removing this from the VO and activating the VLD and matrix headlight function on the Mini? See this video for them in action:
NBCGLX (05-27-2022)
#384
You ask a good question that I'm very curious to hear the answer to. I do believe folks in the BMW world have figured out how to code the additional functionality that is (currently) only offered outside the U.S. I guess the first question to answer is whether or not the U.S. headlights have the same physical capabilities as the non-U.S. matrix lights. That is, do they have the actual components necessary in the headlights themselves. If they do, then the next question is, is there a separate module that provides the matrix functionality? If no, can the existing modules be programmed accordingly with the proper VO code(s), or can the appropriate model be retrofitted?
#385
#386
Question for the group here. I currently have a 2023 Cooper SE on order and it should be arriving in month or so. The car will come with the Mini LED headlights as I understand. My VO currently include the 8S4 "Variable Light Decoding" option on the build. I have been researching to see if anyone has had luck with removing this from the VO and activating the VLD and matrix headlight function on the Mini? See this video for them in action: https://www.youtube.com/watch?v=pxXWuJYXjcI
#387
Hey! I’ve actually tried this on my 2020 F56 and after many attempts with a coder, we found out the USA headlights are different from the European variant and sadly lack the components for Matrix LED. You could totally just replace them with the Euro version, code them, and it would work (the coder mentioned they’ve done this before). I’ve found the part numbers before but can’t seem to locate them right now… I’ll keep looking and update if I find them.
#390
I'm trying to code my power folding side mirrors to fold/unfold on lock/unlock. I got it to work by using the remote to lock/unlock but the door handle buttons dont work. I think if i unlock the door using the door handle, it will unfold the mirror but when i use the button to lock, it doesnt fold. Anyone know?
#391
#392
#393
#395
#397
I didn't see anybody post about doing this previously, but it worked fine:
On my F54 (2019, pre-lci2) I retrofitted a fog light switch into the car. I coded the fog light switch so that it would turn on just the rear left light in the barn door. I coded the brake lights to activate both lights in the barn doors (both left and right).
I was curious if the brake lights and fog light would function under these settings they do. If I turn on the fog lights, just the left barn door light activates. If I then depress the brake pedal, both barn door lights are on. If the fog light is turned off, and I depress the brake pedal, both lights are on.
Now to figure out wiring for the front fog lights retrofit =).
#399
I am a real newbie at this stuff. Hopefully someone may be able to answer a question for me. I have received a 2023 JCW Clubman. I have the pop up display showing speed as well as tachometer. When I move the selector into the manual shift position the circle inside the RPM shows me which gear I am in. Is their a way I can program this to show which gear the car is in even when it is in automatic mode?
Thanks for the help, Steve
#400
Finally found the end of this thread!
Anyways, are there any issues or problems that people run into using Bimmercode. I basically bought it just for the fullscreen carplay, but am hesitant to try it at all due to possible issues and then maybe warranty concerns.
Anyone know of anything?
Thank you in advance.
