Bimmercode App
#102
What I'm trying to figure out is if "coded the indicators in the basic mode - to not monitor and set to LED" does something different than the steps listed for expert mode... and what those different toggles are.
I suspect the basic mode steps are at minimum hitting FRA_H_L_IS_LED and FRA_H_R_IS_LED (left and right rear turn signals), but I don't know what else is being done, as it's not a very specific list.
#103
#104
#105
That's why I need whole thing in terms of expert mode toggles.
#106
Well, that's what I'm trying to find out – the specific parameters that "Coded the indicators in the basic mode - to not monitor and set to LED" translates to.
I don't even have basic mode. I have ESYS (the original "expert mode").
They equate to e-sys commands.
Do not change short circuit.
#107
#108
FRA_H_L[R]_IS_LED => aktiv
FRA_H_L[R]_WARMUEBERWACHUNG => nicht_aktiv
FRA_H_L[R]_KALTUEBERWACHUNG => nicht_aktiv
Right? Nothing else from the 'basic mode' step?
What about BFD_L[R]_IS_LED (et. al.)?
Right now that's set as 'nicht_aktiv' with my stock tail lights ... shouldn't that be modified to LED as well with the new ones?
#109
Ok, so "Coded the indicators in the basic mode - to not monitor and set to LED" means:
Funny you mentioned BFD.
No one has brought that up, not even me!!
I failed to mention that I went ahead and coded the BFD
to LED when I swapped my bulbs to LED. Long before I
Started coding for BFD.
SoI can’t tell you it needs to be done, but it didn’t hurt to do it.
FIY I’m not using UJ lights. I’m using LED Euro tai lights ( amber turn signals)
Did a swap for LED brake and turn signal bulbs months ago. As only the running lights were LED rung.
#110
Rear Fog coding
I was able to code my rear fogs to work as brake lights. But somehow I messed something up and now the main brake light o my lights up the lower part and not the full circle. I have factory led.
#111
Help, anyone?
#112
When you say circle, I think the LED which is the running light, not brake light.
Brake lights have upper and lower bulbs.
#113
Here is a photo of mine. It looks like the top bulb in the brake lamps are not lit now that I have coded the rear fogs as brake lamps. Is this right? Thoughts?
#114
#115
Newbie here when it comes to Bimmercode, please be patient with me.
i just got my Vgate Bluetooth and tried Bimmercode code just the basic function, did not even tried the “Expert” yet.
My question is when I tried to code my changes, it ask for $26.99 for unlocking code. My understanding is, this is just for my changes to take effect on my Mini F60. is this correct ? And do I need to pay additional if I go play around in “Expert Mode”.
Feedback will be appreciated. Thanks in advance.
#116
#117
#119
#120
Interesting thought. Im not sure if thats an option.
I coded mine as a 3rd set of brake lights. I figured I'd get more use out of them that way. I rarely turn my fogs on
#122
#124
The shortcuts to those functions are no longer viable.
They are shortcuts to expert mode, you can always go in expert mode,
and reset your preferences.
There should be instructions at the beginning of this thread.
