Double Head gasket ?
That's a strange one???. I've never heard of double gasketing a head. I'm wondering if the head was shaved too much & that was a nincompoops way of lowering the compression. Before you reassemble that engine you need to determine why it was done. Don't just put it together without first having a competent machinist inspect the head & the top deck of the block.
I'm real curious to hear what you find.
Two head gaskets will do nothing but allow twice chance of leaking.
To check for warpping turn a steal-edge ruler or piece of glass on the edge and place them on the head. Make sure to check diagnally across the head as well as straight across. Use a torch on the otherside and see If there is light bleeding under the straight edge. If it is, then the head is warpped.
Lets hope is was a bloke with no mechanical skills.
Ash
Ash
on
R u sure there was two gaskets ? Cus i just replaced mine and the factory one has two gaskets stock together. Its two thin gaskets connected together at 6 points i think. I think thats what you saw and calling it two gaskets. The new one came the same was my old one was , two thin gaskets.
09-02-2015 09:05 AM
