Gasoline Smell
Gasoline Smell
My '73 Mini has developed a strong gasoline smell. I cannot find any leak on the garage floor. It is strongest near the fuel tank and near the hood. There is no odor in the trunk and very little under the hood.
I'm traveling right now but I plan to drain the tank. I have heard that the mechanical fuel pump can fail at the diaphragm and leak fuel into the crankcase so I intend to have a look at the oil when I get back.
Any more ideas?
Any more ideas?
I had the same thing happen to me on a 93 Jeep Cherokee. The smell was coming into the cabin through the vents so it was hard to identify the source at first.
Mechanical pump leak
Any more ideas?
Any more ideas?
I've a spare in the box mechanical pump if interested. (Don't ask why I bought two) .... or you can blank off the attachment point and go electric.
Have you checked the small breather pipe to the top of the fuel tank inside the boot (sorry trunk!) has not come off (only a push fit) and is also venting through the boot floor? It is also clipped to the rear bulkhead.That fixed it for me once, although you did say there is no smell in trunk.
Mech pump spacer
The spacer only holds the pump off the block and keeps the 'pressure' in....
When I bought a new mech pump I ordered a new spacer....it is still on backorder.....3 years! But it is just a block of rubber with no fluid involved so I appear to be OK
The layer of damp crud on the top of the pump sounds very familiar. I kept thinging bad hose or loose connection and replaced everything 'til I finally accepted that the pump was leaking around the edge... new pump, pob' gone.
Altho I'll note that getting the mounting bolts out on my 1275 was a ***** ... no space to work.... I bought three new tools b4 I got it done. An 11mm ratcheting wrench ended up being the winner!
And b4 anyone else says it - yes, you can blank off the mechanical's mounting point and go electric.....I'm trying to stay one side of the line of 'original' and see this as the other side...today, anyway
Got in last night and clamped off the suction hose on the fuel pump. According to Haynes if the tank is more than half full it will fill the fuel line up to the pump. After wiping the pump body down with some degreaser the smell subsided. There was very little "wet" on the pump but apparently it was enough to stink up the garage.
drrigg
05-27-2022 03:31 AM
09-02-2015 09:05 AM
