cylinder head
Yes, but the block may need pocketed to allow valves to clear. That is not always the case as it depends on head, block, cam, etc...see the tech sections at Minimania. Keith Calver has done a conversion without pocketing so check out his articles & website.
South African Minis had 1098 motors (basically a long stroke 998) with 1275 (12G940) heads, btw...
The above motor was built in 1980 from parts I had laying around. 1100cc block punched out .060 over with stock Cooper S cam and a fully ported/big valve 295 head. By 1990 after many hard miles including autocrossing the guides went away and since I had a 12G940 head on the shelf that was ready to go, I decided to try it. Still have to use the big block head gaskets on this setup. There was a subtle difference with this head, but with a different cam and carburation I think it could really make a difference.
09-02-2015 09:05 AM
