Oil capacity?
No debate?
Originally Posted by Screamer
What type of oil/fluid do you use in the carb? I checked mine today and it is perfect but I have no idea what to buy.
Again - this is a subject of much debate if you research it. The original user documentaion just says use engine oil - a subject onto it self....altho 5w-20 appears to be the conventional wisdom for most street use.
You can 'tune' the performance of the carb by using different weights (viscosities) of oils however. {you do understand the funtion of the oil?} I have been using 3-in-One in the pot of my HIF-6, after seeing several recommendations....yep, 3-in-1. I've been happy with it. I did disassemble the top end of the carb and cleaned the pot/piston and spring, to remove all the accumulated gunk, put it back together than filled with 3-in-One when I switched, not knowing what was in there b4. First importance is free movement of the piston. When I got mine the piston was hanging up, and there was no oil in there. There was gunk in the chamber, esp on the piston spring. Just generic carb crud build up, but it kept things from moving freely. Good time to check what needle(s) you have too.
IQRaceworks
07-15-2022 05:51 AM
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
09-10-2015 12:34 PM
09-02-2015 09:05 AM
Ladybug-S
09-01-2015 07:07 PM
dchang0
08-10-2015 03:37 PM
