Springs
on
Went with Red..
Apprently the different colors each have a different use.. Red for street, blue/green track.. unsure but that's what they told me =P
I'm doing this right now for the simple fact that I'm waiting around for a ship to come and pick it up and deliver it! I don't want to get right in the middle of a full resto and then they tell me, oh your ship is here! haha.. I'm in the military so it's free shipping..
I've never ridden in a Mini with springs. Only cones and 1 with hydrolastic. I can't imagine the suspension could be much better than the cones no matter what you do.
Classicfreq, I'd just like to point out that if you are planning on a full restoration at some point, buy ALL the bits you're going to need now while you can get them cheap. Load them in the car for transport back to the States. I needed 2 new rubber cones and 2 rear trailing arm rebuild kits. I got them, plus a new boot handle, plus shipping from England for less than a single cone from the US Mini parts places.
Springs
I had the opportunity to ride in a Mini a few years ago while I was in Tucson. The owner had done the conversion to springs from cones and also added sway bars front and rear. The ride was solid but not harsh as it tends to get with cones as they get old. He had the "green" springs on his Mini. I will probably switch my MK 1 over to the green springs when I have it closer to being on the road. This guy also recommended green springs as his opinion was that the red and blue were a bit too soft for his liking.
Talk to Mike or Jack @ Seven Mini Parts they have extensive experience with these springs. I believe they have them both on race Minis and street Minis.
This brings up a question... I have a Mini in transport today. I drove it last week prior to purchase. It's the first classic I've driven. Its at '80 Saloon. How do I know if the cones have gotten stiff to the point of needing replacement, either with new cones or with springs? I have no means of comparison, as my other Mini is a MINI.
When rubber gets old, it cracks and then crumbles. I'm assuming that the cones on mine will do that, as an indication of time to replace them. In the meantime, as long as the dental bills from a teeth-jarring ride are less than the cost of upgrade/replacement - I don't plan on worrying about it! The ride is rough - by design. It's not a bug, it's a feature! (There's a minor indentation on my street that at 20 mph, it almost LAUNCHES my mini in the air. It's fun! I hadn't noticed it in any other car, but that's what you get with a rubber cone suspension and a featherweight car!)
Also, the Haynes manual has a maintenance schedule and a check, but I think it's visual - I don't have it handy and don't remember...
When I replaced the rear cones, the new ones were WAY harder than the old ones. I let the car off the jack stand to push the trailing arm up so I could re-attach the shock. It didn't compress enough to get the shock within 2 inches of the bottom of the car. Eventually got it by having both my wife and I sitting on the same side of the back seat, and bouncing, to get it compressed enough to have the 3rd person in the garage able to start the thread. New rubber cones certainly aren't SOFTER than old ones.
Old cones collaspe and lose all resiliency. They pancake out and are hard as a stone causing rough riding.
New cones are not harder. They simply haven't had any compression. New cones will make your Mini look like an off-roader for few hundred miles until they begin to take a set and settle in. People often install hi-los so the can adjust the ride height on new cones to something more appealing. Then again after they settle.
If you're being launched into the air, I suggest your cones may be fully compressed by age. Tough on the car and riders. Cones should be replaced much more frequently than they are. Many Minis go on original cones their entire life. Some say they should be replaced evry 5-7 years.
Steffen.Johnson
42
01-25-2023 02:47 PM
