Converting to modern wiring Harness
Hey guys-
I am considering converting the electrical in a classic to a modern wiring harness (www.painlesswiring.com). I know there are some mini owners who have done this with their v-tech conversions, but I can't find anyone who has done it and kept the mini engine.
I would be running a 1275cc, but thought that converting to a modern harness might eliminate some of the electrical issues caused by the Lucas harness. Is there anything to be worried about since the car will still have Lucas components? Would you just replace the Lucas harness with a brand-new Lucas harness?
Opinions/Suggestions? Thanks in advance.
JMHO: you'd still have the original connectors and the components they connect to. My somewhat limited experience has been that the connectors corrode and/or to components themselves are less that top quality... and they're old. Add to that questionable or deteriorating ground connections. You might be better off reconditioning all the connections using a brass brush or dremel tool, and a chemical contact cleaner. Several other posts on NAM have addressed methods for doing this.
FWIW,
Steve
FWIW,
Steve
As I recall, Minimad or someone else in the Mini bunch was using that or something similar that they got at Advance Auto Parts. Looks like anything the repels moisture and condensation would do the trick.
Related to subject: After I got my Mini and had the thrill of driving at night, I quickly replaced the Lucas headlights (the term 'lights' used loosely) with new headlamps and Xenon bulbs. Money and time well spent. Also replaced the tail, stop and turn signal bulbs with LED versions, which are brighter. Now I need to figure out a way to brighten the lights in the speedo, oil and temp gauges.
Check out Little British Car Company for halogen instrument bulbs. The site is not that easy to navigate nor to post links to the relevant page, they've got 'em.
http://www.lbcarco.com/
Good point, Xanthus. When I did my headlight mod, I had to add another fuse block to deload the std. 4 fuse block of the additional current draw of the Xenon bulbs. (Also put the CD player and tach on the new block.) The two blocks are side by side, but if I were doing a total Mini renovation I'd certainly consider going the way you show.
Also remember that you may have some "creative wiring" done by a past owner. I know I did, and well tracking down issues was insane. Now you COULD put in a new Lucas harness and alter it to include a centralized fusebox. I do not know if that would be easier or cheaper than a painless one.
I have a 62 Austin Mini with many electrical problems thanks somewhat to previous owners and Lucas (Prince of Darkness) I was wondering which Painless kit you guys were talking about and Does anyone know much about the wireing kits that MINI Mania sells they look good and complete but I don't know much about them any help would be apreiciated
ryGuyMCS
10-20-2015 02:24 PM
PSIChocolate
08-13-2015 12:46 PM
DWooderson
08-10-2015 09:12 AM
