Cooper (non-S) Struggles with MFSW retrofit (error codes)
Hello everyone, new to the forum but I've been looking at threads here for a long time
So I tried to retrofit MFSW on my 02 R50, but after doing all the wiring (DME mess, clutch switch & harness) as the retrofit pdf file says and coding the option with ISTAP, neither the SW buttons are lighting up nor the radio/cruise buttons are working.
Upon checking error codes, I saw 3 interesting ones:
- 0x575 (1397) DME: Cruise control, input malfunction
- 0x571 (1393) DME: Cruise control, brake switch - malfunction (I haven't installed a brake switch, only a clutch switch, why do I have this code ?)
- 0x704 (1796) DME: Clutch switch, input - malfunction
So it seems like I've done the wiring wrong, but I cannot find which part I messed up.
While looking at other threads, I saw that 02-04 MC must be having a clutch sensor plate installed which I don't know if mine has and in the retrofit PDF there is no mention of such part.
Also, when buying a used clutch switch from a MCS with MFSW (I don't know the year), I noticed that it was a little different from the one (the difference is very tiny though)
I don't know if I am missing something, if anybody got a clue/a question...
yosip1115
07-11-2022 06:54 PM
firehawk618
Electrical
02-16-2021 09:56 AM
