Show us your Summer/aftermarket wheels
Old 05-16-2012, 01:28 AM
KiwiRob's Avatar
KiwiRob
KiwiRob is offline
I'm not angry, I'm just wondering what made you do it, it won't improve it's handling, it doesn't make it look any better, it won't make it work on rougher roads any better?
  #27
Old 05-16-2012, 11:36 AM
Shady's Avatar
Shady
Shady is offline
That's the beauty of personal preference. I think their CM looks fantastic, and it makes me that much more excited to lift my own.
Props on the great looking rig, KidLuck!
  #28
Old 05-16-2012, 01:02 PM
KidLuck's Avatar
KidLuck
KidLuck is offline
listen... i don't have to explain myself to you or anyone else for that matter. I bought the wheels last summer and decided to go with a more off-road approach this year. I'm in the process of deciding which wheel/tire setup I like best for that application. There are several threads decicated to that interest of which have been substantial help to me. That's why I follow NAM's forum, not to make stupid comments about other owners cars. I like the way my CM looks. I thought others might like to see it too, get ideas from it, maybe help someone out with a question or two... I guess what I'm saying is: if you have something to contribute, do it, by all means contribute. Otherwise, keep it to yourself.
  #29
Old 05-16-2012, 01:11 PM
y8s's Avatar
y8s
y8s is offline
Welcome to the Internet. Unsolicited opinions are provided free of charge.
If you truly don't care what someone else says about your car and its look, then don't get defensive and passive aggressive when you respond to them.
  #30
Old 05-16-2012, 03:06 PM
ChubbyMini's Avatar
ChubbyMini
ChubbyMini is offline
Originally Posted by KidLuck
TSW Nurburgring 20"x8.5" on Contenental DSW 245/40/20s
FinishLineWest lift kit installed.
What is the height from rocker to ground?
  #31
Old 05-16-2012, 04:30 PM
KidLuck's Avatar
KidLuck
KidLuck is offline
y8s: point taken
Chubbymini: I'll get that number by tomorrow
  #32
Old 05-16-2012, 05:21 PM
kconner5's Avatar
kconner5
kconner5 is offline
Agreed I think the car looks fantastic! I'm probably going with the same wheels but moving my Countryman in the opposite direction... Down an inch or two, rather than to lift it... Still it definitely looks MEAN and I can't wait to hear how it does off road
Kyle
  #33
Old 05-20-2012, 05:07 PM
KidLuck's Avatar
KidLuck
KidLuck is offline
Rocker to ground is 11 1/8"
  #34
Old 05-21-2012, 08:42 PM
MotoGreg's Avatar
MotoGreg
MotoGreg is offline
Finally got the car today! Wheels are 19x8.5 +42 with 245/40/19 Potenza RE760 tires. They fit perfect, no spacers required. Thank you to all the people who have posted pictures and specs of their wheel/tire sizes with offsets... all that info was helpful as I was researching what would fit and what wouldn't.
Will probably be putting on the NM springs as well.
  #35
Old 05-21-2012, 10:19 PM
RoyalR60's Avatar
RoyalR60
RoyalR60 is offline
Any rubbing issues?
  #36
Old 05-21-2012, 11:27 PM
jbcola's Avatar
jbcola
jbcola is offline
Do you have better pics off the car? I have 235/35-19 and want to go to 245/40-19.
I'm in doubt about that because the car drives perfect now and i drive it really hard to.
  #37
Old 05-22-2012, 08:38 AM
MotoGreg's Avatar
MotoGreg
MotoGreg is offline
Any rubbing issues?
No. Diameter wise, they're just slightly taller than stock so the tire tread protrudes just barely more than stock, just enough to correct the speedo error.
Width wise, they are 1" wider, but by decreasing the offset 10mm (about 1/2") then that means the inside clearance (distance to strut) was only decreased by 2.7mm, so basically no change there. They stick out 22.7mm more than stock, so now they're flush with the fender (but don't protrude!) instead of tucked inside.
Here are some side pics where you can see that they don't stick out past the fenders:
front...
rear...
And here is one where I stuck my arm inside the front wheel opening with my iPhone and snapped a photo so that I could see how much clearance there was between the tire and strut...
My wife is taking it to work (it's her car) but when she's off Thursday I'll try and get some decent photos, and then once I install the NM springs I'll take pics once again. I know your car is lowered, did you use NM springs, or something else? I looked at pics of your car quite a bit while I was researching wheels/tires.
Your tires are actually shorter than stock at 25.5" vs. 25.9" stock and the 245/40/19 is 26.7" so I would say to switch for sure next time you need tires.
  #38
Old 05-22-2012, 08:54 AM
jbcola's Avatar
jbcola
jbcola is offline
I have the Cobra suspension
  #39
Old 05-22-2012, 11:37 AM
frstrtdmac's Avatar
frstrtdmac
frstrtdmac is offline
Keep us all posted! Im on the verge of doing the same!!
  #40
Old 05-31-2012, 12:07 AM
Carteen's Avatar
Carteen
Carteen is offline
jbcola: Is there any rubbing issues on your car? Any more pictures?
  #41
Old 05-31-2012, 01:17 AM
jbcola's Avatar
jbcola
jbcola is offline
No rubbing at all ;-)
  #42
Old 05-31-2012, 07:13 AM
sgmini2's Avatar
sgmini2
sgmini2 is offline
These are Great Looking- Very Nice
  #43
Old 05-31-2012, 09:25 AM
juannicolas's Avatar
juannicolas
juannicolas is offline
Originally Posted by jbcola
8,5x19" et38 Breyton GTS with 235/35-19 Hankook S1.
do you have suspension?
like your set
  #44
Old 06-13-2012, 08:23 PM
kconner5's Avatar
kconner5
kconner5 is offline
Same wheels as MotoGreg (he convinced me) I have Continental All season DWS (225,40,R19) tires on them right now, it's possible I will get a set of performance tires if I find I'll be doing some track driving.
  #45
Old 06-13-2012, 08:35 PM
Clubman S Turbo's Avatar
Clubman S Turbo
Clubman S Turbo is offline
Hey, its all good, nobody else has to care if your car looks good, just you, its your car, lift it or drop it, its what you want. I personally wouldnt do a CM unless it looks like the CM WRC, thats my hero, but its all in tastes. When my kids grow some and dont fit the Clubbie anymore and hopefully my wallet grows commensurately, Im going to find out how much it costs to duplicate the CM WRC with rear sports seats, for the street. But thats just me. Take it or leave it, its all good.
  #46
Old 06-13-2012, 09:43 PM
MotoGreg's Avatar
MotoGreg
MotoGreg is offline
Wow, I think they may look better on your white car than on our black car.
  #47
Old 06-14-2012, 06:33 AM
TDNparts's Avatar
TDNparts
TDNparts is offline
how do you like the ride? compared to stk?
bouncy, softer, crashing, etc?
I've read that a few ppl said their NM spring felt a tad bouncy, while softer & more comfortable than the factory springs (w/ sport susp).
thanks
  #48
Old 06-14-2012, 08:07 AM
BlackIce's Avatar
BlackIce
BlackIce is offline
Great looking wheels, but isn't that cutting it a little close for chains?
  #49
Old 06-14-2012, 09:38 AM
jbcola's Avatar
jbcola
jbcola is offline
thanks
I had one off the first sets they made for the cooperS. At first i wasn't happy with them, to bouncy in the back but the adjusted (made new springs) them and now it's perfect!
  #50
Old 06-14-2012, 09:46 AM
frstrtdmac's Avatar
frstrtdmac
Cool.. Do you take any 3-4 passengers with you? Hows the ride compare after passengers come in? Also do you bottom out with passengers?
Quick Reply: Show us your Summer/aftermarket wheels
