R50/53 100k maintenance lookouts/heads up?
Old 03-25-2009, 02:29 PM
Stanislaus's Avatar
Stanislaus
Stanislaus is offline
I bought my 03 manual MINI (non s) at 95+k. Now I'm closing in on the big 100. Aside from the inspection 2 stuff, ignition plugs and wires, and four year coolant change, does anyone know of anything to look out for?
I have not enjoyed a car as much as this one since high school, and I want the thing to last as long as possible. Any words from the +100k club would be greatly appreciated.
Old 03-25-2009, 02:56 PM
AutoXCooper.com's Avatar
AutoXCooper.com
AutoXCooper.com is offline
Location: Car Nut Since 1987, Owner Since Fall 2005, Vendor Since Fall 2007
I'm at 90K with an 05 R50 and you might want to check the front control arm rear bushings and the wheel bearing too. If you have the records of service see if the clutch was done before you got it, if not, and depending on how you drive it that would be the big repair down the road.
Old 03-25-2009, 03:09 PM
Stanislaus's Avatar
Stanislaus
Yes, I am eyeballing the clutch-it seems not to have been replaced-only brakes and tires. I think I am easy on the clutch, but I expect it to go south at some point.
Old 03-25-2009, 03:11 PM
Stanislaus's Avatar
Stanislaus
Hey, AutoX-did you have to replace your clutch? I lived in Chi town for 9.5 years...Miss it these days.
Old 03-25-2009, 03:46 PM
AutoXCooper.com
I had my clutch done when they replaced my trans at 48K. I've seen some get less then 100K on the OEM and some get much more then 100K it's all in how it's driven. I hope to get 100K out of mine but the way I drive I'll be lucky to get 50K.
Also note, the "Avg" life of the brakes, pads and rotors is 55K, so make note of when they were done and then plan on seeing that dash light about 55K later.
Go Cubs!
Old 03-25-2009, 03:56 PM
Stanislaus's Avatar
Stanislaus
Cool, thanks. Yeah, I lived in Wrigleyville my first year in Chicago.
No parking, ever. My brother still lives on the South side...
Old 03-25-2009, 05:30 PM
cmt52663's Avatar
cmt52663
cmt52663 is offline
try this collection for more discussion of high mileage...
https://www.northamericanmotoring.co...h-mileage.html
Old 03-25-2009, 05:46 PM
paulgraz's Avatar
paulgraz
paulgraz is offline
Have you changed the gearbox fluid yet? I strongly recommend changing it out for Redline MTL.
Been keeping up with the 2 yr brake fluid flushes?
Belt? (I'm on my 3rd. I try not to run them over 50K)
I've got 132K on my 03 MCS - so far so good. I want to keep it until at least 200K...
Old 03-25-2009, 05:53 PM
Stanislaus's Avatar
Stanislaus
Thank you, Charlie and Paul.
I will press my mechanic to seek out these areas. He seems to be a straight-up guy. I've only had the car for about a month, so I may be playing catch-up with some maintenance issues.
I am feeling like a dope, here. I thought I had a timing chain, not a belt. Are you referring to some other belt?
Gearbox fluid I probably need.
This is my plan, too. After I realized I couldn't afford a 97 mini (or earlier), I kind of stuck with the MINI I could afford. I am feeling die-hard about the little green monster.
Old 03-26-2009, 09:58 AM
paulgraz's Avatar
paulgraz
paulgraz is offline
The belt I'm talking about is the "accessory" belt - not a timing belt. On your car this would drive the alternator and A/C compressor. (On an S it would also drive the Supercharger)
Replacing it every 50K like I've done is probably overkill, but cars typically don't die from too MUCH maintenance. I think MINI suggests this be replaced at Inspection II, or around 60K/4 years.
Old 03-26-2009, 10:21 AM
ClubmanS's Avatar
ClubmanS
ClubmanS is offline
You are also due for new spark plugs..
Old 03-26-2009, 03:00 PM
Stanislaus's Avatar
Stanislaus
*Whew*
Okay, The plan is:
1. Coolant and fuel filter change
2. Plugs and wires (the cables are labeled "2002")
3. Full on inspection 2 with belt change
4. Get second job
4a. Gearbox and brake fluid
5. Imminent clutch replace
6. I think suspension is in the mix at this point?
Thanks, all. I want this car to stay healthy, and I believe in preventative medicine.
vulkandino
10-31-2015 08:29 PM
newminijcw
10-21-2015 02:37 PM
Fourflys
43
10-20-2015 09:42 AM
pkillur
Tires, Wheels, & Brakes
10-01-2015 03:59 AM
yyj3869
09-28-2015 06:53 PM
Quick Reply: R50/53 100k maintenance lookouts/heads up?
