R50/53 Sunroof lube?
I usually use wheel bearing grease. The smell is not too strong and goes away after a few days. It's best to use a small toothpick or burnt incense stick (also good for stirring model paints) to apply small amounts. There are four sets of tracks; take your time and study where the sunroof supports move through them. Two are easily visible along the front half when the sunroof is open. The other two are tucked underneath the seal lines along the back half.
This subject has been brought up in the past, so if you use the search you'll come across some good threads.
One thing I noticed last time I used a heavy spray lube, is I will find some light sticky streaks on my back bumper after it rains or a car wash.
I think it comes from the sunroof drains located under the boot hatch.
It is probablly excess lube that gets washed down the track.
That Kluber site was interesting....they had one specific for "geared sunroofs" in their applications....especially this part: (sorry about the cut and paste, didn't know how to delete the size font thing) and wasn't possible to cut and paste the address bar.
http://www.klueber.com/ the other link from matthew-w had a " ) " in the link....
[FONT=Arial][SIZE=2][FONT=Arial][SIZE=2]
[SIZE=2][FONT=Arial]corrosion protection as well as water[/FONT][/SIZE]
[SIZE=2][FONT=Arial][/FONT][/SIZE]
[SIZE=2][FONT=Arial]resistance.[/FONT][/SIZE]
[SIZE=2][FONT=Arial][/SIZE][/FONT][/SIZE][/FONT]
Probably a good door lube, seat lube, hinges (bonnet and boot) etc....just not sure they sell it in a smaller tube size, but did write them.
[SIZE=2][FONT=Arial][/SIZE][/FONT][/SIZE][/FONT][FONT=Arial Narrow][SIZE=1][FONT=Arial Narrow][SIZE=1]
[/FONT][/SIZE]
[SIZE=2][FONT=Arial][/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2]
[SIZE=2][FONT=Arial][/SIZE][/FONT][/SIZE][/FONT][FONT=SymbolMT][SIZE=2][FONT=SymbolMT][SIZE=2]
ISOFLEX TOPAS L 32 and L 32 N are resistant[/FONT][/SIZE]
[SIZE=2][FONT=Arial]to ageing and oxidation and provide good[/FONT][/SIZE]
Benefits for your application
[/FONT][/SIZE][SIZE=2][FONT=Arial][/FONT][/SIZE]
— [/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2]Exceed OEM requirements of -40°C
— [/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2]Long service life due to high corrosion protection and resistance to oxidation and ageing
— [/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2]Many years of successful use in the automotive industry (specified and approved by most[/FONT][/SIZE]
[SIZE=2][FONT=Arial]car manufacturers and component suppliers worldwide)[/FONT][/SIZE]
[SIZE=2][FONT=Arial]Description
[/FONT][/SIZE][SIZE=2][FONT=Arial]Description
[/FONT][/SIZE]
ISOFLEX TOPAS L 32 and L 32 N have been[/FONT][/SIZE]
[/FONT][/SIZE][SIZE=2][FONT=Arial]designed for extremely low temperatures.[/FONT][/SIZE]
[/FONT][/SIZE][SIZE=2][FONT=Arial]These greases consist of a synthetic[/FONT][/SIZE]
[/FONT][/SIZE][SIZE=2][FONT=Arial]hydrocarbon oil and a special lithium soap.[/FONT][/SIZE]
[SIZE=2][FONT=Arial]ISOFLEX TOPAS L 32 and L 32 N are resistant[/FONT][/SIZE]
[SIZE=2][FONT=Arial]ISOFLEX TOPAS L 32 N also contains a UV[/FONT][/SIZE]
[SIZE=2][FONT=Arial]indicator, which ensures quality checking even[/FONT][/SIZE]
[SIZE=2][FONT=Arial]with minimum quantity lubrication.
Application
ISOFLEX TOPAS L 32 and L 32 N are[/FONT][/SIZE]
[/FONT][/SIZE][SIZE=2][FONT=Arial]especially used for the lubrication of small[/FONT][/SIZE]
[/FONT][/SIZE][SIZE=2][FONT=Arial]gears used in automotive engineering for[/FONT][/SIZE]
[/FONT][/SIZE][SIZE=2][FONT=Arial]electrical adjustment mechanisms, e.g. window[/FONT][/SIZE]
[SIZE=2][FONT=Arial]lifters, sun roofs, seats, headlamps, fan flaps.[/FONT][/SIZE]
[SIZE=2][FONT=Arial]Both products have been approved by[/FONT][/SIZE]
[SIZE=2][FONT=Arial]renowned car manufacturers, such as[/FONT][/SIZE]
[SIZE=2][FONT=Arial]Volkswagen VW TL 778 A[/FONT][/SIZE]
[SIZE=2][FONT=Arial]DaimlerChrysler DBL 6827.40 and[/FONT][/SIZE]
[SIZE=2][FONT=Arial]DaimlerChrysler DBL 6827.41.[/FONT][/SIZE]
[SIZE=2][FONT=Arial]ISOFLEX TOPAS L 32 and L 32 N can also be[/FONT][/SIZE]
[SIZE=2][FONT=Arial]used for:
• [/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2]guideways, bowden cables, door locks
• [/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2]rolling bearings in small motors, fans,[/FONT][/SIZE]
[/FONT][/SIZE][SIZE=2][FONT=Arial]pumps
• [/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2]tooth flanks with plastic/plastic (e.g. POM,[/FONT][/SIZE]
[/FONT][/SIZE][SIZE=2][FONT=Arial]PA and PE) or plastic/steel material[/FONT][/SIZE]
[/FONT][/SIZE][SIZE=2][FONT=Arial]combinations.
Application notes
The lubricant is applied by spatula, brush,[/FONT][/SIZE]
[/FONT][/SIZE][SIZE=2][FONT=Arial]grease gun or cartridge.
Minimum shelf life
The minimum shelf life is approx. 36 months if[/FONT][/SIZE]
[/FONT][/SIZE][SIZE=2][FONT=Arial]the product is stored in its unopened original[/FONT][/SIZE]
[/FONT][/SIZE][SIZE=2][FONT=Arial]container in a dry, frost-free place.
Pack sizes
1 kg can[/FONT][/SIZE]
[SIZE=2][FONT=Arial]ISOFLEX TOPAS L 32 also in 370 g cartridges[/FONT][/SIZE]
[SIZE=2][FONT=Arial]25 kg bucket[/FONT][/SIZE]
[/FONT][/SIZE][SIZE=2][FONT=Arial]170 kg drum
R50/53 Help please.. Odd issue.
PsychoRallye
21
02-17-2019 06:08 AM
Jim Ferrell
10-06-2015 08:09 AM
