Where to get clear coated?
Hellooo..
I've received a carbon fiber hood scoop without clearcoat on..
where can I find a shop taht will do it for cheap + quality?
It's a small piece it can't be really expensive..
on
Since it is a small piece, I'd just head down to my local auto parts store and buy a spray can of automotive clear coat. Follow the directions, smooth sand it between coats and you'll have it looking great for just a few bucks and will have the satisfaction of doing it yourself.
Otherwise, any local body shop will spray it for a reasonable price when they are spraying their next clearcoat. . .
do you recomend specific brand for clear coating?
and also, it seems to be resin coated, what density(?) of sand paper do I have to use to smooth it out while not damaging that piece.?
on
First, I am no expert on painting, but I have successfully painted small parts with great success and nothing but some 400 and 600 grit wet sand paper and an aerosol spray can kit of touch-up paint.
First, I sanded the small pieces with increasingly finer sandpapers: 400, 600, 1000 grit and then washed the pieces. Then I painted the color (which you will obviously omit). I did light coats one each night for 3 days, sanding in between.
Then I sprayed 3 coats of clearcoat. The pieces I painted looked fantastic and an amateur can do just fine on small parts.
One trick about spray painting is to spray from far enough away (8-10 inches), starting the spray while pointing away from the piece and then passing the spray across the piece. Don't do thick coats and wait for each one to dry.
Since I am an admitted amateur, you might get better info here but I do believe that anyone who is a little patient and willing to try something will be happy with their results.
You might also find that any local body shop might spray it for $20 and painting it yourself might be more hassle than it is worth. . . .
Well, I guess I will go ahead and pay $20 or so to get it done..
hah! Thanks!
