paint chips and detailing help
OK, I've been reading some threads related to this topic but they don't quite answer everything.
Here is my situation. My mini has some chips in the paint from rocks, maybe 20-30 of them on the hood/front. I think they are down to metal. I ordered some primer, matching basecoat and clearcoat. Now I have never done any touch ups or really any detail work. I believe I need to do some wet-sanding? I'm reluctant to do that because I don't know what grit to use, or proper technique. Anyway, here are my questions:
1. What other materials do I need to fix these chips, and what is the proper method of doing the repair?
2. Can you explain to me the process of detailing the car after the paint chips have been fixed? i.e., there is wash, wax, polish, paint protection, etc. -- what's the difference between wax, polish and paint protection? What do I need to make the car look good and protect the paint?
I looked at all the Prima care stuff, and it sounds good -- just don't know exactly what I need and in what order to use it.
Sorry for such basic questions! Just never had a car that I wanted to take such good care of before!
Thanks everyone!
Thanks everyone!
Do not do whatever you are about do you will regret it, I suggest you find a person that has done it before and can show you how to apply the touch up paint, if thats all you want to do you will not need primer or clear. Its a touch up, it will not be perfect. You will however need something to remove excess paint after doing touch up there are products mentioned in several threads concerning that.
Good luck and be patient...
I will respond in more detail in a bit..gotta take care of my kid this morning first.....be back with answers.
I couldn't agree more. You will pay MORE in repairing the damage if you opt to wetsand your touchup without knowing what you are doing!
Thanks everyone!
Thanks everyone!
Ok well if you've never wetsanded before, and it looks simple enough, then go ahead and try it. The worst that can happen is you sand through the clear coat, or you sand too much that you can't buff out the scratches, you'll need to respray it. Otherwise yeah, doesn't seem difficult at all.
Check out the Langka web site to see if this is something that might work for you. It sounds like you might have lots of chips, making this a little impractical, but who knows. You'll be an expert by the time you're done!
I have used it with good results, as long as I remember that it is a touch up, and it will be imperfect. MUCH improved, but not perfect.
www.langka.com/
www.langka.com/
I was looking at Langka last night after reading about it in a thread. I read some mixed reviews on it. At any rate, I have a 98 Jeep Cherokee with some paint chips, I have touch up paint for that, so I think I'll practice on the Jeep and see if I can get good at the repair before I start in on the mini. The Jeep is just a utility vehicle and I'm not really concerned with the paint. And if I'm not doing a good job on the Jeep, then I'll find someone to help me out with the mini, I've already been talking to a guy. Said depending on what we do, it could cost between $300-$600 with a warranty. Upper end would be with a total respray on the hood, which I'm leaning toward...just do it right the first time, ya know?
Excellent idea practicing on the Jeep, its really not that hard just take your time. I do it for a living, so do people in your area, go to one of the larger car lots and as the used car mananger who they use to work on lot cars, or better yet just look around the lot,they are probably there.
We always are....
We always are....
We always are....
We always are....
