Vacuum
try checking the site for north american car car: http://www.nacarcare.com. so far every product i have purchased from them has been great!
If you're looking for a portable vac that you can use anywhere or keep in your MINI, I recommend the Vac N Blo Jr.. It's a 12 volt vacuum that runs off of your car battery. This is the first 12 volt vacuum I've used that works.
If you want a vacuum with a little more power, that you will also use around the house, try the original Vac N Blo, which has enough power to suck start a leaf blower!
No matter what vacuum you choose for your MINI, make sure it has the ability to both vacuum and blow (and has blow attachments). I use the blow feature as much as I do vacuum to blow the dust out of the vents, racks and crevices that you just can't reach with suction. Use the blower along with a soft Detailing Brush and the interior of your MINI will be spotless.
db
db
10-01-2015 12:13 PM
potterstein
09-13-2015 09:57 PM
