Tagged!! How to remove permanent marker from paint?
I walked out to my car tonight and found that the driver's side door had been "tagged" with some graffitti!! It's black and does not appear to be raised above the surface of the paint. I rubbed it with my fingers and nothing lifted off or smudged, so I'm assuming it's permanent marker.
Any tips for removing this? Didn't want to go at it with any solvents (e.g. acetone) that might melt the clear coat.
Thanks in advance!
Thanks in advance!
That's too bad.... I'd be pissed if I were you. Anyway, if you suspect it's permanent marker, try marking over a spot w/ a dry erase marker. dry erase markers are sometimes used to remove permanent marker if they're accidentally used on dry erase boards, etc. If by chance it works, maybe you can use a paint cleaner to remove any residual left over?? Good luck.
any good cleaner wax should remove it, best results if the surface had been previously waxed. If cleaner wax doesnt do it a mild polish will take it off. Same with spray paint it it were ever tho happen again.
One other thing you can try that is very effective on many things like marker, sap, some glue is rubbing alcohol ( 70% isopropl )
Good luck, I hope it comes off without too much trouble.
Be sure to wax after you get it off.
Thanks in advance!
Thanks in advance!
Hope a cheap fix works
My Girlfriend ran over a paint can.... That is bad!!!!!! It exploded, and had white paint all over her Black Car...
We ended up removing it with automotive paint thinner, but it left some swirl marks on the finish... but that is better then the white and black look....
Good luck getting it off..
07-16-2020 12:54 PM
R50/53 R53 Chrono Pack - gauge?
missinmyjeep
08-22-2015 07:13 PM
