I mounted my new tires (myself) yesterday, and used stick on weights to balance them. In my infinite wisdom, I applied some super glue around the weights to keep them from coming off. I did two of them whilst the wheels were facing down and didn't realize that the glue was running out onto the face of the wheel. I washed the car today & found the glue. Of course there's break dust in the mess, to boot.
I tried rubbing compound & alcohol without success. I'm afraid that acetone (& related cleaners like Goof-Off) will remove the finish of my beloved Rewinds.
Suggestions much appreciated!
why did you use superglue on your self-mounting weights?
anyway, i would mask off the surrounding areas and take some
polish (maybe even wet sand it first using 2000 or higher grit) to
remove that gunk. i think the only way is to take your time and
sand/polish it off.
I've used stick-on weights for years and they always tend to come off. I've used a dab of superglue in the past & that always cured the problem. I was in a hurry this time & didn't realize the amount that was coming out.
What kind of polish?
Dude....hobby stores sell a product called 'uncure' that dissolves cyanoacrylate glue (super glue). It is non corrosive and is not a solvent. It only attacks the glue
