Do I Need a Porter Cable Polisher?
#51
I have the California blade too and I like it a lot - I have to use a lot fewer monster fluffies to get Clara dry My current process generally involves a wash, partial dry with the blade, and then Prima Hydro. But it depends on how sunny it is outside when I do it. Some day, when I can get my husband to remove all of his CRAP from the garage, it won't be an issue *sigh*
Just wanted to mention... although the Monster Fluffies work well to dry (and then there's the "fun" factor in using the Monsters!), the Waffle Weave Drying Towel really works better for drying. It's weave pattern is much different and is designed to optimize the microfiber's absorbing abilities. (I know, I know... you recently ordered already! Maybe something for next spring...)
-Heather
#52
lighter you stroke the better it works. ive not had the foam
come out of the holder.
#53
#54
maybe you should hot melt the foam into the handle?
#56
#57
Two waffle weave towels from DP is actually perfect for drying a MINI. I can't dry an entire MINI with one before wringing it out. Not that wringing it out is bad, but as soon as it's wet, it doesn't absorb as much as a dry towel when removing the remaining water spots.
I actually use one waffle weave and one microfiber drying towel--but I would just as quickly use two waffle weave towels for drying.
#59
Um Heather, my Slick bottle has a defect and I would like it replaced. Seems that all the Slick is just about gone!
#60
I used to use and love the California Water Blade. I'm sure i still have it buried somewhere. The problem is if there is so much as a grain of dirt that may have flown on your car, it is being dragged across the paint. And you still need to use a towel to dry all the crevices and small panels.
It was replaced by The Absorber.
Then by the Mr. Clean Autodry and just letting the car air dry (using the absorber only when I need it dry asap in order to wax)
But now I am back to bucket washing, I still go over once with filtered water from the mr clean, and now use a waffle weave microfiber towel (this one), which is not only just as absorbant as the Absorber, but much softer on the paint so you can actually wipe. And freakin' huge...you can definitely do the whole car with just one. And like others suggested I do pre-wet it with filtered water as I had been doing with the absorber as well.
#61
I am thinking of getting a Jelly Blade for pre-drying but I am curious about what you said. To me, if you get a grain of dirt on your Mini, won't the towel drag it across the paint just as bad as the Jelly Blade will
#62
#63
Scott
#65
By the way, did you get the local e-mailer about this week's holiday open house? Lots of good sales in the retail store... (and a wine tasting tonight!). You can check the website for more details (under Events), but I will give you a tip... come by between 1 and 3 on Saturday if you need more Slick. And that goes for any locals! (sorry, out-of-towners... )
-Heather
#66
-Heather
#67
Yeah, I'll bet it has a defect!
-Heather
-Heather
BOGO - So if I buy 100 bottles of Slick I get 100 bottles for free? I'm so there!
#68
#69
This is good advice for a car that's been previously waxed. However if the water doesn't bead because you haven't waxed it in 6 months or more, you will have a much harder time trying to blow the water off.
Compressed air also works if anyone has an air tank. I use a small 2.5 gallon pancake compressor. It's really too small for home use---the motor is always on filling up the tank so it's loud and vibrates a lot but it only cost me $30 from Kragen.
Richard
Richard
#70
Update:
Got Octane's video for Christmas--it's all it's cracked up to be!! Honestly, I was expecting it to take me several days (or weeks) to get through 2 1/2 hours of car detailing video--but I ended up watching the whole thing in one morning! It holds your interest long enough to do so.
Now need to pick up the PC, pads, product, etc.
Thanks again, Dana
Thanks again, Dana
#71
Woohoo another happy customer! Thanks for the kind words. Glad you liked the DVD.
Richard
Richard
Update:
Got Octane's video for Christmas--it's all it's cracked up to be!! Honestly, I was expecting it to take me several days (or weeks) to get through 2 1/2 hours of car detailing video--but I ended up watching the whole thing in one morning! It hold your interest long enough to do so.
Thanks again, Dana
Thanks again, Dana
#73
If you plan on only using the PC for waxing, you should think about the time saving of the PC versus having to do more masking. When I wax by hand, I mask where paint and trim meet. With a PC, you'd have to mask more in case any wax flies off the pad. Example: I mask with one piece of tape between my wheel arches and the paint. If I'd use a PC, I'd have to cover the entire arch and maybe even the tires just to be safe.
I plan on getting a PC soon but just thought I'd mention this ...
#74
I'm using a jelly blade and LOVE IT. So far no scratches/spiderwebs that I can see from using it. I'm meticulously clean with it and rinse and inspect it before each use. But it's nice to be able to push off most of the water (including from my cabrio top) and then finish up with the MF waffle... I may someday have a scratching experience and regret all this - but so far so good...
#75
I also watched it in a single sitting (FFing through a few repetitive things - I only need to see someone buff off wax ONCE - but I know there are others who need the remedial buffing examples). And it was INVALUABLE in preparing me to use my new PC on my project van (as well as proper technique for claying, and hand polishing with ScratchX, and all kinds of other great tips).
Well worth the money!
