water spot on windows
I notice that when I wipe my windows with Meguiar's nxt window cleaner and an mf towel, I see vertical drip lines in the glass. Yet, when it is dry I do not notice them. I wonder what that is. I plan on getting some glass polish soon though, I am guessing it is due to some chemical or what?
My theory is that they are little tine flecks and pits in the glass and due to the angle the sunlight is striking them, makes them very noticeable. It only happens to aggravite car nuts! The only way to fix it is to replace the glass, but it will happen again.
If you're talking about adhesive residue--Goo Gone works well. Clay bar may help remove any remaining residue.
As for waterspots on glass I try the following:
1.) Clay
2.) PC with M80
3.) Vinegar
Yes, you can safely use the PC on glass. I do this with the Meguiar's W8006 pad and it cleans up water spots very nicely. You can then wipe with Clarity glass cleaner.
Richard
1.) Clay
2.) PC with M80
3.) Vinegar
Richard
rain-x has some cleaning agents in it that i like. i use it more for
removing the streaking wiper lines and to extend the life of my blades.
just remember to wipe off the thing real well using some water (i use distilled).
no hazing.
Unfortunately there is no exact equivalent. The black pad is softer than w8006 but stiffer than w9006 finishing pad.
So white pad is closer to yellow. Honestly everyone should just buy one yellow pad and be done with it. LOL.
Moshu-Clubman
R55 :: Clubman Talk (2008+)
07-13-2016 08:54 AM
