SCDA HPDE Schedule
#2451
#2452
#2453
#2454
Had a pretty good 3 days at Watkins Glen. First day was open track followed by 2 days of typical HPDE with class and scheduled time on the track. Ran the ZIIs and 17" wheels on Friday and things went well. The ZIIs squeal like crazy but have reasonably good grip. I made a scoop style brake duct that seemed to help keep the rotors cooler and reduce the pad pickup I have been having a problem with. Saturday I tried the 15" wheels with the RE71Rs and found that none were balanced right, so back to the ZIIs while the 15" wheels got rebalanced. Afterward I did 2 sessions with the 15" wheels and found that they really trapped heat, which argavated the brake pad deposit issue. So Sunday was back to the ZIIs. I also had one of our driving coaches go out with me. He helped with some fine points and I found I was drifting around one of the turns, which left him chuckling.
A few things to note. The owner of an M4 didn't replace all of his wheel studs when one broke. All 5 then broke on one front wheel in a high speed, high g load turn and he lost a wheel, went off the track into the tire barrier and flipped the car. Then it got so hot on Sunday that people were cracking brake rotors.
As for the brake pads, I am going to switch from the Wilwood Poly H to the Hawk DTC 60. These are the favorite of the E30 drivers and that car is similar in performance to the MINI. I'll let you know how that works.
#2455
#2458
These were bedded sometime last year and I have maybe 6 track days on them. They run ok on cooler days. They have problems when it is hot out and it is worse with the smaller wheels, which seem to trap brake heat.
I bed them with used rotors. I have a 6 mile long hill that I can go to and get good heat into them without having to go too fast. From speed I slow aggressively 6 - 7 times and then drive home. They will be pretty stinky when I am done. Pretty standard bedding procedure.
#2459
#2461
#2462
Crap that crack is no good
You did get me thinking that I might try a dedicated set of rotors with a matched set of pads and see if that helps.
That crack (and the one forming below it in the picture) reminds me that someone at the event I was at had a rotor explode coming out of a turn. It ripped a 1 foot by 6 inch chunk out of the barrel of the alloy wheel, ripped out the lower control arm and I don't know what else. I think it might have been caused by uneven heating (inside to outside) of the rotor.
#2463
#2464
Just signed up for the Patroons chapter of BMWCCA event at LRP on July 29th. Yup, instructors and class room, and time on the track. Not for everyone, but I have learned that as I have become better the less I know about driving. It is almost always helpful to have an instructor in the car for a session or 2. I have had some great ones.
If interested, sign up and come and join me for a romping good frolic around this little bull ring. Oh did I mention that it is on a Saturday?
#2470
Woo Hooo!
it will be great to see you there. My Cousin will be there too with his M2. Not sure what Zre, veggi are doing.
It seems that SCDA is still allowing 2005 helmets but they need to be SA.
I think you will find that everyone is changing or will be. It surprises me SCDA hasn't. Snell has changed their testing between M and SA as they find that the SA needs to protect for the hard hits against the roll cages. Not sure why it matters for street cars, though. Maybe legalese. I did get a 2015 helmet on line for under $200.
#2471
#2472
Elivan said SCDA will change over next year to the newer helmets. A lot of clubs must have prohibited SA2005 helmets this year because it's almost impossible to find SA2015s in stock. I found one but it wasn't easy.
RE: IMSA @ LRP — I definitely can't go Saturday but maybe Friday. What exactly is the MINI corral? Is the Street Tuner class race on Friday?
#2474
