Drivetrain Air con pump not kicking in?
Old 06-01-2007 | 12:09 PM
fozworth's Avatar
fozworth
Ive just regased my air con and have noticed the the pump isnt kicking in.Any idears as to what it could be.I will of coarse check the electrical plug is secure on the pump,but is there a fuse for this? .And is there any other way of testing it?
Old 06-01-2007 | 12:16 PM
Loony2N's Avatar
Loony2N
There is a fuse and there is also a relay that will cut out the a/c compressor if in and out pressures are incorrect. Sure you did the recharge right?
Old 06-01-2007 | 12:21 PM
fozworth's Avatar
fozworth
Basicaly we have just changed the engine and also a new radiator ,plus the ECU had a JCW remap .We had to empty the air con system so i took it to a garage yesterday now the car is all back together .They presure tested it and then filled it with AMMOUNT 410 of air con coolant.I did wounder if the ECU might need coding for air con .But as for the relay and fuse not sure ,where are they.?
Old 06-01-2007 | 08:04 PM
herbie hind's Avatar
herbie hind
i'll bet it's some kinda low pressure switch. whether mechanical or what to prevent the pump dumping refrigerant with a leak . i'll check my bently but don't hold your breath.
Old 06-01-2007 | 08:20 PM
herbie hind
i got nothing . no trouble shooting for the a/c. they do say to replace the receiver/dryer if the system was open for 24 hrs. still it doesn't sound related . . someones bound to help . sorry .
Old 06-03-2007 | 05:59 AM
fozworth's Avatar
fozworth
Have checked the connector on the pump.checked the fuse,its ok,relay cant see that it would have gone while the engine was out.But i wounderd if the ecu needs a fault code clearing if the air con gas was discharged while the engine was removed.Although the battery was disconnected.But then i connected it back up before i took it to the garage to get it refilled.Also i had the ECU reflashed with JCW software .so would that make a differnce?
Old 06-03-2007 | 06:26 AM
Paul Webster's Avatar
Paul Webster
Have you got the pressure switch connected properly, it wont work unless its seeing the min pressure
Old 06-03-2007 | 08:50 AM
fozworth's Avatar
fozworth
Where is the presure switch,i only reconnected the wire/plug on the pump itself ,and i think thats just the electric feed isnt it?
Old 06-03-2007 | 09:07 AM
Paul Webster
On the right hand side corner in the engine bay under the plastic tray what holds the fusebox etc, follow the small air con pipe from the front and you'll see it.
In theory you shouldn't of touched it but you never know you might of knocked it.
Old 06-03-2007 | 09:41 AM
fozworth's Avatar
fozworth
I cant see it but is that because ive cot a alta CAI kit.Is this switch a proper on of type thing as i dont remember turning anything off
Old 06-03-2007 | 10:03 AM
Paul Webster
Its a pressure sensor which tells the ecu how much pressure is in the line, if it doesnt see the correct pressure it wont switch the pump on.
Old 06-03-2007 | 11:52 AM
fozworth's Avatar
fozworth
We did touch the sensor switch but if we emptied the air con gas while the engine was out and then reconnected everything including the battery apon startup the ECU would detect that there was no gas wouldnt it,so would this just need a fault code reset to reconfigure everything.
woodstudio
03-15-2020 09:28 AM
W0TM8
12-19-2019 08:50 AM
coachvminis
08-25-2015 07:58 AM
damncajun
08-17-2015 09:25 PM
Ambient Thermal Management
08-07-2015 01:27 PM
