and got to drive my baby for the first time in 3 mos or so... she sounds soooo nice! 8 am... 80 something degrees... :( but got to beat up on an RS6... didn't pull as hard as I wanted... but had about 6 car lenghts by the time I hit 5th gear at 7500 rpm...
Yeah...mine is pretty old...97 Tony Kart with 125 Yamaha...
Those are still competitive, I have a 99 set up for the over 35 gang w/JC built Honda 80.
So, at Mid Ohio,did you get to 120+? If, at speed, a kart can't teach you respect for a car.........
WOW ! The fender vents looks really nice. Fits the body lines great. I want a set!!
Sid ......I agree .....there is always room for more gadgets and gauges !!!!!!!! Does anyone have us beat yet ??
I have a solar panel connected to my MINI when it is parked to keep both the batteries fully charged.
Yes Closer to 125 white knuckle miles per hour...tried very hard not to stare at the tiny wheels spinning at those speeds
Before I got on the track, I thought this would be a cake walk as the track is so large for the kart but noooo...you can still kiss them concrete walls if you don't watch what you're doing...the only thing faster than my 125s were the 250
Unfortunately, I backed out of the vent install when I realized the amount of body work and removal of the wash bottles...some lucky guy is probably installing right now...
Solar?!?! I have a miniature styrene burning dynamo...the black smoke helps block the hot sun too...
Glad I went with other vented ones, they did not require removal of the washer bottles. Just gave them a quick shot of rattle can black so you can't see them through the vents.
