Drivetrain Volt Exhaust
Old 07-12-2007, 05:55 PM
polizei's Avatar
polizei
polizei is offline
Can anyone get a sound clip up? I'm interested to hear what it sounds like...
-Cody
  #27
Old 07-12-2007, 06:12 PM
littlehandegan's Avatar
littlehandegan
littlehandegan is offline
Coordinator :: Low Country MINIs
They posted one under vendor announcements
  #28
Old 07-13-2007, 01:59 PM
littlehandegan
Ok got it installed...sounds great...but if sticks out of the bumper almost 4 inches and leans to the right.....taking it back to get the other bracket bent b.c my cars and 04....but dang that thing sticks out way to much....but for 375 cant complain
  #29
Old 07-15-2007, 02:15 PM
astromini's Avatar
astromini
astromini is offline
will the volt exhaust fit 06s?
  #30
Old 07-16-2007, 05:41 AM
Detroit Tuned's Avatar
Detroit Tuned
Detroit Tuned is online now
Vendor - 15 Years
Like it sent in the PM, it's all in hows it's adjusted on the car. you can have it site flush, a bit of stick out, or a lot of stick out. you should just need to move the rear section back a bit and slide the center pipe more into the rear section as you do this.
Note: every car is different and the adjustment will be different for every car. but as shown in this thread. the tips can fit flush to the bumper.
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
  #31
Old 07-20-2007, 07:31 PM
El_Griton's Avatar
El_Griton
El_Griton is offline
It sounded good when I was behind you today.
  #32
Old 01-14-2008, 11:28 AM
ozarkroots's Avatar
ozarkroots
ozarkroots is offline
Coordinator :: Mini's of the Ozark Region
Up date on the VOLT exhaust
I recently purchased a VOLT cat back exhaust from Detroit Tuned.
After I placed the order I saw a sound clip on you tube labeled 118 db and it was LOUD. At that point I was a little worried that I had made a horrible mistake. Detroit Tuned assured me that everything was OK.
I installed the system in my garage Saturday in about 1 and a half hours with help from my son. Since my "S" is an 06 and the system was made for an 02 or 03 there was some concern but we installed it using only the outside hangers. It is a little tight but everything seems to be OK. The Volt is well within a reasonable sound level both inside and out. I rate the stock system as 10 and the VOLT as 12. There is a slight increase in burble.
All in all I am very happy with the VOLT at this point but I will repost if things change.
  #33
Old 01-14-2008, 02:17 PM
UKCoopeR's Avatar
UKCoopeR
UKCoopeR is offline
if it is the clip i am thinking of, that car also had a non-stock header
  #34
Old 01-15-2008, 10:28 AM
Detroit Tuned
Vendor - 15 Years
i am happy you liked it. we try not to sell any junk here. if i had a lot of problems with the system or people really hated it i would not sell it. i worked with this system for a month or so before i released it to the public. we test fit it to a car and drove it for a while back and forth to work for a month to see how the sound changed and thing fit. the burble is the best part about this system. i like it so much that i have thought about installing on on my own car (i have 1/2 a Milltek now). if i would not install it on my own car, i would not sell it.
It is also true that any exhaust system will be louder with a header. it will almost double it.
  #35
Old 01-16-2008, 07:21 PM
2002redMCS's Avatar
2002redMCS
2002redMCS is offline
so how are the performance gains on this? Im real interested in getting one, but am worried about the performance...can anyone feel the difference?
  #36
Old 01-17-2008, 06:18 AM
Detroit Tuned
Vendor - 15 Years
you can expect the normal 8 to 12 hp gain. each car is a bit different.
  #37
Old 01-29-2008, 10:11 PM
PGT's Avatar
PGT
PGT is offline
how loud is this compared to a Milltek? On a scale of 1-10, if stock is a 1, a Milltek a 2, the Alta Sportone a 4?
  #38
Old 01-30-2008, 10:12 AM
littlehandegan
Sounds alot like the magnaflow....perfectr IMO....burble is perfect....
Jack
  #39
Old 01-30-2008, 10:25 AM
PGT's Avatar
PGT
PGT is offline
yeah....magnaflow is WAY too loud with the header I have. BTDT
  #40
Old 01-30-2008, 10:27 AM
drocay's Avatar
drocay
drocay is offline
I have the Volt and I love the way it sounds.
  #41
Old 01-30-2008, 02:47 PM
littlehandegan
Doug are you runnning the RMW? Hi flow or catless?
jack
  #42
Old 02-09-2008, 03:51 PM
100percentcotton's Avatar
100percentcotton
100percentcotton is offline
Got it like a month ago and burble is like no other. Got it from Performance Peddler for $250. I personally didn't have that hard of a time installing it, but I have an '02. I did however have to heat one of the tips up and bend it up a bit, no big deal, but it came a little bent and not perfectly even.
  #43
Old 02-10-2008, 07:24 AM
limster's Avatar
limster
limster is offline
I had a similar experience as you did. I got my exhaust from Performance Peddler for the same price, the tips needed to be worked on. I have a feeling that Performance Peddler gets the Volt exhausts that are 2nds while Detroit Tune gets the good ones. That could explain some of the price difference between the two.
  #44
Old 02-10-2008, 11:57 AM
OSUBeaver's Avatar
OSUBeaver
OSUBeaver is offline
I just got mine from performance peddler for $254 with free shipping all the way to west coast. The resonator had a slight ding, and there we some scratches, and I think my tips are slightly off too. The the slip joint to the resonator was really tight, but the slip joint to the muffler section was really loose. The first night I didnt have exhaust clamps and I could see exhaust coming out of the slip joint.
All in all I'm really happy with the system. For the price it can't be beat. I do agree though that DT must get the Grade A one's and PP has the banged up ones. I'm pretty sure DT wouldn't let one get out the door if it was in the shape mine came in.
Sound is deep but definately louder than stock. So far I'm enjoying the sound, but I haven't put many miles on it. I haven't driven in a Mini with a different exhaust to compare, but it's way louder than my buddies MKIV GTI with full turboback Milltek
  #45
Old 02-10-2008, 02:52 PM
100percentcotton
I read on another thread that Performance Peddler supplies Detroit Tuned with the Volt exhaust. Whether or not that's true, I have no idea. But I agree, for the price, this exhaust cannot be beaten.
  #46
Old 02-21-2008, 01:06 PM
1FSTMINI's Avatar
1FSTMINI
1FSTMINI is offline
ordered mine today so we'll see what shape it comes in being he said they were new with no dents or scratches since i def asked that Q to them. They said they only have 8 or so left and will let them go for $250-$300 depending on where its going.
  #47
Old 02-22-2008, 01:05 PM
richplay69's Avatar
richplay69
richplay69 is offline
Got mine from performance peddler for valentines for $255 and installed it that Friday. It sounds awesome when you give it a little rev in neutral... and you just can't beat the price!! When I first drove it I didn't really like how freakin loud it was, but it has grown on me... i just feel like everyone is looking at me when i leave the red light and get up to speed It looks just like the Magnaflow too. everything lines up good too... except the right tip is just a hair crooked, or maybe I'm just looking at it too hard. And, while driving for the first two days it smelt like my car was on fire but i realized it was coming out of the exhaust... guess a little bit of packing material got in the exhaust or something. But overall I recommend this exhaust to anyone who wants a cheap (price wise; it is stainless steal) , fairly loud, good looking exhaust.
  #48
Old 02-22-2008, 01:18 PM
Squirlz's Avatar
Squirlz
Squirlz is offline
Detroit Tuned will be installing one of these for me next month in time for the Dragon. Looking forward to it!
  #49
Old 02-22-2008, 01:54 PM
1FSTMINI's Avatar
1FSTMINI
1FSTMINI is offline
id use performance peddler for the price. they have a few left for under $300 shipped depending where you live.
  #50
Old 02-22-2008, 02:55 PM
Detroit Tuned
Vendor - 15 Years
Only 7 exhausts left in the country.....
patsum
26
05-29-2021 06:29 PM
shorenetworks
11-04-2019 06:18 PM
embiggenedmini
10-15-2015 12:36 PM
buckeye_hunter
09-02-2015 01:24 PM
09-02-2015 09:05 AM
Quick Reply: Drivetrain Volt Exhaust
