Drivetrain K&N filter oil does NOT foul MAF's - "Official" pledge from K&N
#26
The oil problem is more apparent with the gauze/pleated type of filter than with the foam type. It is very easy to over-oil these filters and thus contaminate the intake path. If you are careful about oiling, you probably won't have a problem. But it is easier to get a foam filter oiled properly than it is the pleated type.
#27
#28
Here you go. Sorry for the delay. I've been causing trouble in another thread.
This discussion was my first analysis right after I started using a gauze air filter.
http://theoildrop.server101.com/foru...rue#Post853636
This next analysis was when I went back to paper with the exact same type of oil. Notice how the iron and tin have gone down significantly.
http://theoildrop.server101.com/foru...rue#Post918131
My very first analysis, which is on the report, was with paper as well.
#29
on
Any figures on the the amount of negative pressure (suction ?) created behind a filter in say the R56 compared to a NA engine of at least 3 litres in size ?
I ask as I was wondering if it was a lot higher in a small displacement turbo car and that the oil was being "sucked" off
Same oil issue was around on my 2002 GTI when I had one.
Just a thought
Just a thought
#30
#31
I ran a K&N cone style filter in my 1998 F150 for about 100,000 miles after replacing the stock filter at around 25k or 30k miles. I cleaned and re-oiled it about 3 times in that period. Never had a MAF sensor problem. I sold the truck to a buddy at 127,000, and he has around 167,000 miles on it, and I believe he still has the K&N (I'll have to check with him). Still no MAF problems, anyway, as I talk to him every few weeks. The truck uses no perceptible amount of oil at 5k mile change intervals.
That being said, I don't know that it proves anything...
Kimolaoha
07-05-2023 01:04 PM
M7Speed
08-06-2015 01:48 PM
