Drivetrain Official ALTA™ Q&A thread PART TWO 2nd Generation MINI
Old 12-02-2007, 11:57 AM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
ADAMSALTAMINI is offline
In my car, I used the Water Temp and Boost. I would have added an oil temp as well. You can mount three, but the third isn't as easy to read, so something like oil temp is ideal there as you don't stare at it all the time.
Hope that helps! Thanks for asking!
  #502
Old 12-03-2007, 12:07 AM
chuntington101's Avatar
chuntington101
chuntington101 is offline
Originally Posted by a96bimmerm3
In time. APR has a big fuel pump for FSI cars and I know a place to get some injectors. Controlling it is a PITA but in time we'll be alright. I think 300whp is attainable on the stock fuel setup. After that, who knows.
sorry to go off topic a little but was thinking about the fuel issues. the VW guys can push their 2.0ltr FSi turbo engines to over 400bhp. is there any reason this levle of power cant be achived with the MINi (just on the fuel side)???
thanks Chris.
  #503
Old 12-04-2007, 09:00 AM
lttletimmy's Avatar
lttletimmy
lttletimmy is offline
when will guages be up on your site? I've hinted to some people that I'm interested but they're lost without everything on the site
  #504
Old 12-04-2007, 09:03 AM
ALTAPerformance's Avatar
ALTAPerformance
ALTAPerformance is offline
SOON!
In the meantime, pm me to get on the list! Sorry for the delay.
  #505
Old 12-04-2007, 10:56 PM
scott48's Avatar
scott48
scott48 is offline
Will the ATP Boost Source Adapter from JSC Speed work properly with the soon to be released boost gauge, the actual sensor that screws in?
  #506
Old 12-05-2007, 07:21 AM
ALTAPerformance
Having not tried it I can't say for 100%. However, it certainly seems MORE than reasonable that it would. WE did confirm that we will be offering something similar in about 3-6 weeks. So either way you will be a-ok!
Thanks again! Let me know how I can help!
Adam
  #507
Old 12-05-2007, 07:32 AM
Candyman's Avatar
Candyman
Candyman is offline
Sorry to jump in here on the Alta thread, but yes it will work.
It has a nipple for a vacuum line that will run to the boost pressure sensor for the Alta gauge.
All aftermarket electronic boost gauges use a MAP sensor w/ a nipple fitting, so you simply run a line from the Boost Source adapter to the MAP sensor for the boost gauge.
  #508
Old 12-05-2007, 11:08 AM
scott48's Avatar
scott48
scott48 is offline
Does the boost sensor for the Alta boost gauge setup have a nipple on the end of the sensor?
  #509
Old 12-05-2007, 11:26 AM
ALTAPerformance
Yes the boost gauge has a sensor, and it has a nipple that will go directly to the adapter in question. No issue no problems!
Thanks again!
  #510
Old 12-11-2007, 11:02 PM
scott48's Avatar
scott48
scott48 is offline
You guys gonna offer a clutch upgrade in the future?
  #511
Old 12-14-2007, 10:08 AM
XaLia's Avatar
XaLia
XaLia is offline
Adam i need your help..Could you please tell me if the front bumper from the aero kit needs any modification so the intercooler can be installed??
Thanks!!
  #512
Old 12-16-2007, 06:18 AM
Marwan's Avatar
Marwan
Marwan is offline
Hi ADAMSALTAMINI, I want to know more about your intercooler V2. I found it on a website but not so much data. Please let me know about the water injectros, why are they there and how do they operate and what does trigger them. Also, how do you compare your product with M7's V2. I like the shape of yours but I live in Saudi where it's tooooooo hot and I prefer performance over look.
  #513
Old 12-17-2007, 04:00 PM
ALTA2's Avatar
ALTA2
ALTA2 is offline
Manufacturer
Thanks!!
It should go on with ZERO issues. WE installed one of these on Unichips R56, and it was just like the other cars.
The V2 is only for the R53 supercharged car. Is this the car you have? The water injection is a great item for hot climates! here are a couple things to read over:
http://www.altaminiperformance.com/p...jection-System
https://www.northamericanmotoring.co...d.php?t=122263
https://www.northamericanmotoring.co...ad.php?t=95030
  #514
Old 12-18-2007, 06:03 PM
chili_red07's Avatar
chili_red07
chili_red07 is offline
ALTA your X-Mas special kicks @$$!!! (can't wait for the t-shirt!)
  #515
Old 12-19-2007, 11:10 AM
ADAMSALTAMINI
Thanks guys and gals!
  #516
Old 04-22-2008, 10:10 PM
FugitiveAI's Avatar
FugitiveAI
FugitiveAI is offline
Time to fire this one back up!
What's in the pipeline Adam?
  #517
Old 05-04-2008, 09:13 PM
ADAMSALTAMINI
TONS! I will get a list going ASAP! Sorry for letting this one die!
  #518
Old 05-07-2008, 07:23 AM
PH1L's Avatar
PH1L
PH1L is offline
will their will b an boost gauge that measure in bar?? rather than psi
  #519
Old 05-07-2008, 07:28 AM
ADAMSALTAMINI
WE can get metric for you at any time. We don't stock it that way, but just let us know via PM or e-mail and we can order one up for your gauge kit.
Thanks for asking!
  #520
Old 05-07-2008, 09:35 AM
MINIchaser's Avatar
MINIchaser
MINIchaser is offline
Hey there! I know when I get my MINI the first thing I want to do is get your CAI put on it. I looked around and searched through this thread and couldn't seem to find any info on whether or not the CAIs void any type of factory warranty. I'm pretty 99.9% sure they don't, but I'm having trouble convincing my dad of that...(he wants me to wait until the warranty is over to put anything extra on my MINI )
Thanks for the help!
  #521
Old 05-07-2008, 10:23 AM
trojanman's Avatar
trojanman
trojanman is offline
Originally Posted by maximusGeek
Do you have any data on the number of decibels your cat-back puts out? We also have noise laws in CA.
Just thought I'd chime in on this since I'm a california police officer.
CVC 27151 (b) states you may not exceed 95 dBA. However, it also states you may not modify the exhaust in violation of 27150, which states your muffler may not make "unusual" or "excessive" noise. Technically, you can be stopped and cited for having ANY aftermarket exhaust on your car.
However, in practical application of this law, we will not harass anyone unless:
1. We are given a special enforcement direction.
2. We believe you are a shady character and we need a reason to stop you and get in your car.
3. You are doing all kinds of other stupid driving and we want to throw the book at you.
  #522
Old 05-07-2008, 10:27 AM
ADAMSALTAMINI
No warranty issues with the intake. If you want you can search some other threads you may find some addl information.
Let me know if I can help further.
  #523
ADAMSALTAMINI
WELL PUT! Thank you for the input!
  #524
Old 12-05-2008, 11:12 PM
ADAMSALTAMINI
bump! This needs to be back on top for a bit.
  #525
Old 12-05-2008, 11:15 PM
ADAMSALTAMINI
"Kirkland:
Adam,
Is it possible to program the DME to not light up the instrument panel with the CEL I have every start as a result of the Alta downpipe?"
Well yes and no! We need to find out what the code # or numbers are, then we can figure out where to go for a solution. We want nothing more than to help resolve the concern! Let me know in a PM or post here.
Thank you!
Quick Reply: Drivetrain Official ALTA™ Q&A thread PART TWO 2nd Generation MINI
