Drivetrain Rotational vibration after lowering
#51
Ok lets keep this in line a little and simple.
Do they lower the springs anymore than ours, or any less? If the height is the same, for 100% its not the springs or axles, or something its the install or alignment. Can you think of any other variables with the install? Again, there is no way that Mini didn't allow the axles to be ran a different heights (esspecially only 1" or so up and down) then maybe mini has some potential issues coming. I have yet to feel this vibration in the cars. When was your car built?
We have about 5 guys we have done in the last month or so, and none of them have the issue (r56 guys), not to mention quite a few others. Clubmans, R56's Manuals, and Autos, 07's, 08's and none with problems.
We even have both shop cars with H&R coilovers (lowered even more) and they have no issues. You say proof, well, in our eyes, they seem to be just fine, and only a few guys across the country have the issue. Using what data we have, there are two variables with the cars across the country that is how they are being installed and the alignment they are getting. I have said this before, but once a week, we get alignment shops asking US how to align them (not specs but physically how to to it)
You have to remember, this isn't necessarily an ALTA spring issue, but a spring issue in general, or coilover issue, or overall height in general. I know some have said that the axles have to perfectly aligned in order to work right, this is sooooo not true. CV are meant to work at lots of angles and lots of angles for their whole life span. If on the Mini the angle is effecting somthing that causes a vibration, then something else isn't built correct on the car. At least that is my assumption.
If enough people work together here, we can figure this out, but making statements like "the ALTA springs came off, and no more vibration, it must be the ALTA parts, don't buy them" should be stated more accurately like:
"I changed the springs are my car today and it changed the height X amount, and now the vibration is gone!"
With that kind of attitude, a resolution can be had............
#52
I've delt very little with ALTA in the past (I, in fact, will call them tonight/tomorrow due to an out of stock item), but they seem like a friendly bunch. It could be simply that your messages were either misplaced, lost, or just plain didn't go through. I've heard nothing but good things about ALTA.
Maybe the initial installation was poor, and maybe it got fixed the second time. Who knows...
Thanks again!
#53
I have had the same problem, the "experts" here say it doesn't make sense but it does happen and is directly related to the operating angles of the inner cv on the passenger drive shaft.
More here:
https://www.northamericanmotoring.co...after+lowering
Camber plates may help. Some have suggested repacement of the drive shaft or a "wear-in" period.
My MA was aware of this issue. Take a look at the angles of the shaft on a hoist (lifted by the wheels) and you can see what is happening.
Good luck. Ignore the "experts" on this one.
I should also add I had the issue with Eibach lowering springs, sold them to another NAMer who did not have a problem, have the problem on coilovers, with alignment. Camber plates not installed yet.
More here:
#54
Funny how you make people look bad on the forum...here is your reply to my message after I posted this:
Re: Lowering Concerns after H&R installation.
This will be my last post in regards to the springs issue. I had enough dealing with Alta and your poor leadership. Good luck!
Again love the edit!
I just checked ALL of my PM's from the past week and ZERO from TampaMCS.
I answer PM's at ADAMSALTAMINI
Jeff Perrin / Chris in Tech at ALTA2
Ken Jubb Sales Dept ALTA_KEN
John Leitl Wholesale Sales ALTA_John
John Herring Marketing and Web Concerns ALTADESIGN
If I have missed one someplace PLEASE let me know where you sent it? I can't answer what I don't have.
Hope that helps! Thank you!
#55
I know there are a LOT of intelligent people that read these threads, chuckle to themselves and don't comment. Those that have the ability can read what has happened and how ALTA HAS tried to help. But for those that skim through, I MUST make this post.
Did you hear back from the gent you sold the ALTA springs too? He replied to another thread and didn't seem a bit happy. I wonder how YOUR customer service will be for him? I offered to help him as well EVEN THOUGH THE PARTS ARE USED!!!!! How much better can ALTA be to clients?
Sheesh...........
#56
[SIZE=3][FONT=Times New Roman]I also have this issue H&R vibration- I have lived with it for 5k miles. I purchased mine through a different reseller - Tire Rack. Mine were installed by someone who works on minis normally, I have taken it back to them but the issue of course does not present itself with the mechanic in the car. I have also had an alignment "right after the 2nd time the mechanic looked at the car". [/FONT][/SIZE]
[SIZE=3][FONT=Times New Roman]Either ways thanks to those who try to help.[/FONT][/SIZE]
#57
LOL
This is crazy!! I love the back and forth part!
Anyways.. I have been dealing with Alta since I got my 2007 Cooper S. I have installed:
ALTA BOV
ALTA SWAY BAR
ALTA H&R Springs
ALTA CAT BACK
ALTA CAI
ALTA INTAKE TUBE
I had a problem with the BOV sticking.. emailed Adam.. received an email back within 1 hour of how to fix the problem.DONE.. Everytime I have dealt with Alta I have been happy.. sometimes I would get frustrated on OUT OF STOCk parts becasue I am the type that wants it right away.. but Adam would email as soon has the parts are in his shop! and they would have it shipped out ASAP to my tunning shop.. If I had any concerns or questions I would just email Adam or Ken and they would spend A LOT of time explaining stuff to me and helping me out.. CRAP Adam helps me on weekends!!
Anyways I have lowered my 2007 with Alta H&R Springs and I have no problems at all.. I just recieved my RSS H&R Coilovers and they are getting installed in 2 days and I am slamming it to the ground.. i will let all you know how it goes and if any vibrations happen.
I am on NAM to help others and to learn as much as I can, I am not here to listen to people trash talk.. if you want to do that go to: www.jerryspringertv.com
Thanks!!
ALTA BOV
ALTA SWAY BAR
ALTA H&R Springs
ALTA CAT BACK
ALTA CAI
ALTA INTAKE TUBE
Thanks!!
#58
ALTA BOV
ALTA SWAY BAR
ALTA H&R Springs
ALTA CAT BACK
ALTA CAI
ALTA INTAKE TUBE
Thanks!!
ALTA BOV
ALTA SWAY BAR
ALTA H&R Springs
ALTA CAT BACK
ALTA CAI
ALTA INTAKE TUBE
Thanks!!
#59
On the other hand if Mini made them too short, it could do some weird things. But you have remember that the axle doesn't pull in and out much going through the normal range of motion. I bet it doesn't even move .500".
Again, this is still leading to something with the cars, not parts. If the same parts work on one guys car, and not on another then its got to be something with the car.
We are trying to be helpful to everyone here, and with enough guys giving us data about build dates and springs, and what not, we should be able to narrow this down.
#60
#61
We have an 07 R56 S that has the H&R springs on it. I have been noticing a feeling in the first thru third gears that can best be described as something off balance. I thought that maybe it was a damaged pressure plate but now I am wondering if it had to do with lowering the car. If you are wondering why I thought of the pressure plate, it is because my wife learned how to drive stick in this car. Although she did a fantastic job learning and never abused the clutch while I was with her.
#66
Adam...when my car arrives, I am driving down to see you guys and have you install either the H&R Springs or go all out on the H&R Coil-overs. I have been following these suspension threads closely and am wanting to lower my car and have it done right. My car doesnt arrive until September, so it will probably be October when I want the work done.
--chad
--chad
#67
OK FOLKS!!
I took out my H&R Springs and installed my H&R RSS Coilovers, and SLAMMED the car to the ground.. No vibration, nothing at all! Only difference is that the car is GLUED to the ground! SWEET.
And I haven't even alligned it yet!
So it must be the car build.. Anyways I will post pictures up shortly.
Thanks!
Thanks!
#68
--chad
--chad
#69
OK FOLKS!!
Thanks!
Thanks!
#74
"All springs are shot-peened to increase the service life of each spring by more than 200%. Each spring is then sent through the H&R exclusive “SuperBlok™” system, which cycles each spring to ensure that sagging will never occur. Lastly, the H&R special powder coating process coats each spring with a flexible and durable finish that is highly resistant to corrosion, chips, and scratches. At H&R we care about quality –– the whole production process, from start to finish, is done in-house to ensure the most consistent, highest quality product possible."
#75
OK FOLKS!!
Thanks!
Thanks!
--chad
--chad
