Drivetrain oil change
oil change
OK, so I go to my local auto parts store to see if they carry an oil filter that will fit the Mini - it is not your standard filter. The dude looks it up on his computer - a Fram oil filter is like $21 and a Puralator oil filter is like $6. Is the Fram 3 1/2 times as good as the Puralator? They did not have the Fram in stock and I did not want to get the Puralator until I confered with NAM. Which also got me to wondering - who makes the Mini oil filter? I doubt Mini manufactures it themselves - it's likely outsourced to someone. But who?
I think the OEM is made my Mann. Personally, I'd go for OEM, especially since it's a canister design. I've heard NAPA has a Wix filter that works pretty well too. A filter at your dealer is only going to cost a couple bucks more than that Purolator; or you can get them online at several of the aftermarket MINI companies.
Personally I don't like the NAPA oil filter for the MINI. The NAPA filter has plastic ends and it tends to fall out of the housing when you remove it, throwing oil and filter down the back of the engine. Since the filter falls out, it probably doesn't seal around the center tube of the housing as well as the stock filter.
If you want Mann filters, I recently purchased a box of four from this URL:
http://germanfilters.com/
They are located in PA and I got my filters in a couple of days.
Never had this happen to me.
Jim
Kimolaoha
07-05-2023 01:04 PM
