Drivetrain Milltek Downpipe No Longer Avail in US
This is a response I received from Stratmosphere when asking about the Downpipe to go with my Milltek cat back exhaust.
Sorry about that. There is no plan to release that product for the future. Best that we know, no other tuner in the world has solved the issue long-term.
The issue is the check engine light coming on with the downpipe installed.
I have emailed Milltek to find out if this is true, that they are abandoning the US market for one of their products.
If other NAM members have their cat back and were thinking of adding their downpipe please email them and ask them to fix the problem and release the revised downpipe in the US.
Pete's statement "no other tuner in the world has solved this issue long-term." is troubling too. I haven't heard of any problem with the Alta Downpipe setting off the check engine light.
Would like to hear from members using Alta's downpipe and exhaust about any issues they have had with the check engine light. Or if anyone has the Milltek downpipe have you experienced the problem? If you have, how did you resolve it.
Does anyone know if Alta's downpipe would fit with the Milltek cat back exhaust?I hope this isn't true. I'll post the reply if I receive one from Milltek but they are closed until after the New Year.
Cheers and hope everyone has a great New Year
on
That is odd that they would do that. Might be the catalyst they use is to blame. Still strange.
Looking at the photo online, it would appear that the ALTA DP would work with VERY minor changes, and the use of a step down V-band adapter is certainly something we can provide if needed.
Let me know what you decide to do!
Thanks again for considering ALTA to go with your Milltek system!
Adam, thanks for the input. Very disappointed in Milltek. If it turns out they are not going to try to solve the issue you'll have a new customer. I'm going to wait till early next year to see if they respond or if Stratmosphere get's an update from Milltek.
If the downpipe is truely not available, you will have a new customer for the downpipe along with the Unichip and possibly the CAI.
Please let me know the extent of the minor changes needed to add the downpipe to the Milltek. I have a very good shop up here in Seattle, Zahntech, who did the install. Matt commented how good the welds and fit were when he installed the Millteck so hopefully he will be able to handle the minor mods if it comes to that.
Darn, I went with Milltek due to the sound, the tips, and a friend has there system on his Audi S4 and he just raved about it.
Oh well, live & learn and it's not over until the fat lady (Milltek) sings!
I never expected Milltek would give up on a fix for this and I'm hoping other members will contact Milltek or Stratmosphere and urge them to fix the problem.
Cheers!
Cheers!
on
Cheers!
Cheers!
The mods would only be to the connection at the cat-bcak to the ALTA dp. Any qualified shop could do it. When you get serious, let me know. I can have you take a couple measurements and then I can say exactly what you will need. Sorry for the crappy situation your are in. Let me know!
on
Hope that helps!
In some states a downpipe is an emission violation, even if it does pass smog. Check only stations also pass or fail you on visual appearance. They will tell you that you need an executive order for the part. I understand the EGT sensor is in the up-pipe, but alot of times when you modify the turbo outlet (downpipe), the EGT throws a CEL. If it is the O2 that is throwing the code, then the vehicle just needs a tune or the cat efficiency isn't up to spec...I'm guessing the later.
I actually installed one of the Milltek Downpipes. It did make power and a good sound but the CEL came on. We tried a few things to get rid of it but had no luck. I talked to Milltek and they basicly said in not so many words that they would have to redesign it to make it work. So we will see how long it take, but don't know much more than that.
Good thing I sell both Alta and Milltek can always keep a customer happy.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
on
In the case of the Milltek, the catalyst supplied (or something) isn't able to keep the catalyst inefficiency code off. So the CEL lights P0420 for that reason.
You mention up-pipe. If you came from the Subaru world, then those cars have an up-pipe that on some years (02-05 WRX, FXT, LGT) they have a preturbo catalyst that is monitored by an OEM EGT probe. Removal of that probe in that vehicle can cause a separate issue for a CEL. That wil shut down the car if not installed.
Hope that helps!
I have read in MINI literature that the ECU limits the EGT to 950 degrees in order to protect the turbo. Is this false? Or is there an EGT sensor installed elsewhere (pre turbo maybe)? Or is it inferring it from the readings of other sensors?
Sorry to poke at you with questions. I am just having problems rectifying information I have from two trustworthy sources, and the MINI engineers aren't members of a message board that I'm a member of.
Navigation & Audio HK Replacement With New Components
Filmy
15
06-06-2023 06:27 AM
joshuatrost
09-05-2015 02:58 PM
