Drivetrain Views on MSD Coil Pack and Best Plug Wires
Old 01-09-2008 | 01:47 AM
scolburn79's Avatar
scolburn79
Hi,
Just trying to find out whether the Stock ignition coil pack is the best or whether the MSD is the best to use, and what are the best Plug Wires to use. As in Brand. Thanks in advance.
Old 01-09-2008 | 06:41 AM
minimusprime's Avatar
minimusprime
Old 01-09-2008 | 06:45 AM
MiniStupidfun's Avatar
MiniStupidfun
I have had the Msd coil packfor about 2 years.... it looks cool Im sure there is some minute difference.
Old 01-09-2008 | 07:08 AM
ScottinBend's Avatar
ScottinBend
The stock and the MSD are rated the same voltage......but it is RED ! (that's why I have one..... )
Unless you want the bling factor now, wait to replace the wires until needed
Old 01-09-2008 | 10:34 AM
jaynicholson's Avatar
jaynicholson
Kingsborn wires are highly regarded and come with a heat resistant sleeve.
Old 01-09-2008 | 10:36 AM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
The diffrence is the color....bling bling
Old 01-09-2008 | 03:35 PM
Silkworm's Avatar
Silkworm
When i bought my 03 used it had Live wires and the MSD coil. The live wires conections rusted out/corroded but the MSD has not given me any problems. As far as performance i doubt it however I do not know what a stock mini feels like anyways since mine had a bunch of aftermarket on it already.
Old 01-09-2008 | 04:52 PM
ScottinBend
Old 01-09-2008 | 05:15 PM
norm03s's Avatar
norm03s
Originally Posted by Silkworm
When i bought my 03 used it had Live wires and the MSD coil. The live wires connections rusted out/corroded but the MSD has not given me any problems. As far as performance i doubt it however I do not know what a stock mini feels like anyways since mine had a bunch of aftermarket on it already.
I agree with minimusprime & scolburn79
and OEM wires too.
Save you mod money for something that makes s difference unless your into color coordination.
Had corrosion with the OEM wires and coil terminals and now it's happening again with after market wires on an OEM coil. I used dielectric grease when I installed them not that long ago, guess I didn't use enough to keep moisture out.
First hint is static in sync with engine speed at idle while tuned into a weak AM radio station, check your coil connections you'll most likely find corrosion on the terminals.
Old 01-10-2008 | 06:37 AM
Kentiki's Avatar
Kentiki
I just recently found a tiny bit of what looks like rust on the wire terminals where they meet the coil. I guess this is NOT normal!? Can it be fixed with dielectric grease, or do the wires need replacement?
Ken
Old 01-10-2008 | 08:24 AM
ScottinBend
Just clean the contacts and lube it up good with the grease.
iggi
17
09-02-2023 03:06 PM
W0TM8
12-19-2019 07:50 AM
blackie
10-02-2015 07:41 PM
yukinoinu
09-20-2015 09:10 PM
yashmack
08-15-2015 10:16 AM
Quick Reply: Drivetrain Views on MSD Coil Pack and Best Plug Wires
