Drivetrain unichip compatibility
YES, for sure. The harness is not even close. While it is possible to hard wire the Unichip into the harness it not recommended as reversing it is VERY expensive. Mini Mania has both the Generation I and II in stock-
http://new.minimania.com/web/SUBTYPE..._Inventory.cfm
Hey guys. Sorry for the confusion that Don has placed above. Obviously not familiar with the product or the car in this case.
Mike has it nearly nailed!
The hardwire is REALLY ez on the R56. We can sell you a harness and instruction set. If you do the wiring farther back on the harness and invest in some felt tape like the OEM uses, you could nearly NEVER tell it was even there.
Your biggest problem that was not eluded too above is the R53 uses a different ECU brain vs. the R56. So hardwiring it in isn't a problem, it simply won't work. There aren't enough drivers on the old ECU to run the R56.
Hope that helps! BTW: We have the NEW style harnesses PnP style and ALTA Programming should be available next week!
Let me know if I can help further!
No confusion in my mind. Our experience is very first hand as one of our cars was the very first generation II MINI Cooper S to have a Unichip. We provided the car to Unichip for the initial development.
The real advantage of a Unichip is the ability to simply plug and unplug the unit to keep the Dealership happy. The hardwire process took me less than 1 hour to do the last one we did. But the cost to replace the harness to regain acceptance by a dealership is where the real cost is. The dealership wants almost $1,000 to replace a harness in an '07.
Sorry for any confusion. The Unichip for an R53 will NOT work on an R56, regardless of the wiring method.
and they have the 2007 R56 version on sale for $599
TIA,
Richard
Hope that helps! Thanks for asking!
Tires, Wheels & Brakes
10-01-2015 10:38 AM
10-01-2015 10:17 AM
10-01-2015 08:55 AM
