Drivetrain ALTA mod choice help
i would say go to a custom exhaust shop and have a magnaflow put on first. then with the money you save get the alta intake. after that get the boost tubes. you live in hot houston right , so as soon as you can add the intercooler, i believe you cant go wrong with cooler air charge. then ecu it or downpipe it , that is the stage im at. once you have de power then get the wheels and drop it. and most important have as much fun as you can . doing this stuff is fun.
and EXPENSIVE!
Well I'm partially choosing ALTA because I know you get what you pay for (price = quality) and partially because I know that if I have any trouble that you'll always help
ALTA = FAST MINIS
I'm keeping the order i originally had, but all the advice was very helpful! Thanks to all...
Tyler
First off thanks for all the help everyone
ALTA = FAST MINIS
Tyler
ALTA = FAST MINIS
Tyler
Before you put this one to bed are you prioritizing parts by power gain, appearance, price, or sound?
If its max gain, I'd say Intercooler then turbo back exhaust
If its appearance and/or sound, I'd go CAI and Catback
Pricewise, the CAI and Inlet/Boost Tubes are as much together as each of the other parts.
I just installed the boost tubes and turbo inlet and though they really don't look like they would add anything they most certainly did add both power and MPG efficiency.
I am not sure if you are the DIY type, but I definitely endorse that. If so I highly highly recommend going through Adams how-to sticky threads and having every tool he recommends on hand for the installs. They will save you a ton of frustration!
patsum
26
05-29-2021 06:29 PM
