Yesterday I had a strange thing happen. I boosted to about 10psi from a 30mph roll and heard my car pinging (pre detonation) I quickly go off the gas. I was not sure if thats really what it was so I tried again and same thing...sounded like a bunch of marbels in a can. I quickly got off the gas. I drove home and picked up my brother...i wanted him to hear the noice to confirm what i was hearing. For whatever reason I could not get it to ping again? 91 Octane Shell, 83 Degrees, flat ground. I was about 1/2 through my tank of gas and it has been running very strong. This morning I drove it and no problems at all? Why would it ping for a few rolling runs and then not again?
Thanks!
maybe its a bad gas - mayby its a bad kharma try to use hi-octane gas one time, and try to drive when U have less than 1/4 of tank - if the problem goes again - look (and photo) your plugs - maybe they dead
It could be carbon build up in your combustion chamber creating hot spots that are firing the charge prior to spark. Pop out your plugs and take a peak at your piston tops. A few guys here have used 'Sea Foam' to de-coke their combustion chambers and piston tops. Good luck!
Jeremy
Sea Foam FTW! Worked wonders on my Miata. I put it in the oil, gas tank, and through the Throttle Body.
Yep...Blackfoot, soon to be Moscow as I head there for grad school! Not really that many MINIs around here, I imagine there is more going on in Boise right?
Thats funny about the pinging, because when my car was stock i for the most part (except track events) ran 87 octane, 10psi, not a single problem. even now with gas over $4. I am considering going back to 87 because I never use boost on the street (responsible driver)
tjack do a search on ticking sound . a "card in the spokes " sound can be heard on many members' cars due to it has been found, the pre 05 harmonic damper . if your symptoms are the same i suggest you contact randy webb for a used 05 damper . luck .
