Drivetrain OBX Catback
Here is my original review and a thread on the OBX Catback.
https://www.northamericanmotoring.co...ad.php?t=50963
https://www.northamericanmotoring.co...uct/117/cat/33
Still running both the OBX header and the OBX Catback. System has mellowed nicely and have had no problems since installed.
If you got any questions after reading the above links - drop me a line.
ever since i wanted to pull the trigger on the obx they suddenly disappeared off ebay... strange! but thanks for helix and sparktec i'll check them both out!
If your going to do this - print the pics showing the cat graphed for your installer - makes things easier. Also mount the header and then measure distance between header and your exhaust system. Its important that the made up piece fit correctly. Too long and it will push your exhaust tips out the back and place additional pressure on the donut flange. Too short and it will pull your exhaust tips in and add pressure to the donut flange. Also make sure to double nut or use copper nuts on the spring loaded donut connection point or they will come loose and you will be back under the car.
the old obx threads lay out all of the little things that could cause you a problem. This is the value of NAM for you learm all of the little pit falls. I followed all of the recommendations and have had no problems w/ the OBX header.
W/ Helix you eliminate the fabrication portion of the cat to header. If you have a good shop that can mount the header and then cut old cat off and weld on the flange then your fine. The weld should be SS.
If set-up properly they work just fine. I referenced earlier the importance of measuring the space between header and exhaust. This is the space you fill w/ the cat and it needs to fill that space - not pulling or pushing on the exhaust. I suggest to everyone - go w/ the donut and see how it goes. If it fails replace, if it doesn't you got some change for another mod.
I have both but only the exhaust on as of now.. I did not use the resonator from the old unit so it has a louder note...But a good deep note with quite a bit of burbble... The only problem was, the weld broke in only a week that held the two rear tips together.(not a real problem though)
When you install - definetly spend the time to ensure port match up. Mine matched up pretty good and I did not need to tweak.
In the spirit of helping out however you can call me on my cell and I will take you for a ride so to speak. If this is of interest drop me a PM w/ you number.
Hey Guys, I just got My OBX exhaust from eBay.
I'm wondering if anybody would be interested in an install turorial/pics? It involves cutting the stock system so it's not just a bolt on. I'm gonna be putting it in tonight or tomorrow. If so drop me a line and I'll post 'em up when i do it.
W/ Helix you eliminate the fabrication portion of the cat to header........the old obx threads lay out all of the little things that could cause you a problem. This is the value of NAM for you learm all of the little pit falls. I followed all of the recommendations and have had no problems w/ the OBX header.
Steve
molala
10-02-2015 01:53 PM
Shane Wendel
09-18-2015 06:18 PM
atenzany62
08-26-2015 09:26 AM
