Drivetrain Turbo-back, when/warranty/install...
A few turbo-back exhaust questions:
1) How long a break-in period before modifying?
2) It's my second Mini, so I know that Mini is liberal about mods under warranty, but do they view a turbo-back differently than a cat-back?
3) Has anyone attemped a self-install without access to a lift?
TIA,
Richard
TIA,
Richard
A cat-back is basically just a different muffler & some tubing after the functional parts, while the turbo-back includes the highly monitored first cat.
I really can't tell you how frustrated I'm getting with mine, if I could pull the whole thing off & get my money back, I think I would.
The stubby antenna looks great & takes 2 seconds to R&R, radio reception's been just fine.
The headlight protectors were a real challenge to install, I actually got a complete kit w/ the fog light protectors as well, but after fighting w/ the headlights & looking at the much more curved foglights, I just skipped it.
I would recommend having them professionally installed, like window tinting, it's just not worth the hassle. That being said, I'd still recommend buying a set, the Mini's blunt nose is a real rock magnet.
The fault's a catalyst efficiency fault, catalyst bank 1 below threshold. Alta originally thought it might have been a software change for the '08''s, or that it might be one from a less then optimal batch of cats, then I was told there was a TSB & a software update, but after numerous calls & arguments with the dealer, the TSB's only for R53's and they won't touch the car w/ the Alta exhaust on it ... so, waiting for another batch of cats.
to R&R the cat, make a trip to the dealer in another city to get a software update they don't want to do, and then reinstall the DP yet again, that's a huge PITA factor, and if I didn't have a hoist & tools of my own, it'd be a big expense as well.
That's why I shelled out almost $1500 for a bolt-on part from a reputable company.
I'm in the same boat with the P0420 issue with the Alta turboback. Can't seem to get a clear answer on when they will get a working replacement made available. I've had the problem for three months now. I ended up buying a scangauge II to erase the code when it comes on (every couple of days), but having to reinstall the exhaust is going to be a pain in the *** (assuming they do come out with a working model).
Its a fitting commonly used in the VW community to eliminate cels with high flow DP's and no cat straight thought exhaust.
It places the O2 sensor in the direction of the exhaust flow. Over 400 miles no cell,
On my girls car she originally had a cell when first turned on the car, but went away quickly and has not returned for over 600 miles.
a little late but I thought I'd chime in on this one.
I getting the P0420 constantly with my Alta DP. It was fine for almost six months then within a few weeks after installing the unichip, I started getting this code, and the frequency increased over time. At first Alta and myself thought it was the Unichip or harness, but now I believe that the extra exhaust output as a result of the Unichip just accelerated the onset of the problem as it still happens now without the Unichip on the car. Alta isn't sure if it is a defective cat design or if the MINI ECU is just extremely sensitive to changes in flow.
Regardless it's a big problem and is still unresolved.
Thanks again! let me know if I can help in anyway personally. Chat soon!
Thanks for the post and sorry we are in limbo on your car. Jeff and I completed testing on another solution that he will be offering to you as well. You may be correct that the addl fuel is causing the concern, but seems more likely the harness. REGARDLESS we appreciate the business, the opportunity to fix it properly and your patience. ALL are appreciated.
Jeff has been in contact and we'll continue working toward resolution. Though I'm really disappointed with the issues I've had with a few parts, Alta has been tremendously supportive. For this I still believe you are a good vendor.
I don't think it's the unichip, as I'm still getting the same code incessantly long after removing it and it's the only code I've gotten.
I PM"d you trying to get some info to call you today. Jeff (ALTA2) wants to get you on the phone to try the newest solution.
Hope to hear from you soon!
Drivetrain Another turbo-back exhaust bites the dust
jeffm5150
05-30-2009 09:35 PM
