Drivetrain Were to start Modding?
Old 07-07-2008, 01:23 PM
KPMINI's Avatar
KPMINI
KPMINI is offline
OK, I have enjoyed my 2006 BRG Cooper S very much. It is the best car I have ever owned.
So now I would like to know where I would need to start doing some modification. This is my daily driver, and will continue to be that way. I would just like a little more on the fun side to enjoy driving my Cooper S even more.
Any and all suggestion will be appreciated. Also does anyone know if the Water to Air IC is a good option for an Arizona Car?
Thank you in advance for the assistance.
Happy Motoring.
- KP
Old 07-07-2008, 01:26 PM
AutoXCooper.com's Avatar
AutoXCooper.com
AutoXCooper.com is offline
Location: Car Nut Since 1987, Owner Since Fall 2005, Vendor Since Fall 2007
heres a good thread from this weekend dealing with much the same.
https://www.northamericanmotoring.co...d.php?t=146578
Old 07-07-2008, 01:31 PM
KPMINI's Avatar
KPMINI
KPMINI is offline
Thanks I had looked that one over, however, since I have the dreadded Automatic, I thought that I may need to ask from a new stand point. I know that I will be some what limited due to this.
Happy Motoring.
- KP
Old 07-07-2008, 01:35 PM
silversmoke06's Avatar
silversmoke06
silversmoke06 is offline
Umm Read. use search.
And as always use the pulley luke.
Old 07-07-2008, 01:39 PM
BlimeyCabrio's Avatar
BlimeyCabrio
BlimeyCabrio is offline
First thing to start modding is your budget. Because once you start, you're screwed.
Old 07-07-2008, 01:43 PM
Phantom's Avatar
Phantom
Phantom is offline
Happy Motoring.
- KP
Id start by puting in the 6 speed but really intake and exhaust is are some nice mods, and a 19mm rear sway bar will change your life.
Old 07-07-2008, 01:49 PM
BlimeyCabrio
Not so much. Read my blog. The big limitation is that, for practical purposes, the car won't go over 6750 RPM.... so raising the rev limiter doesn't do anything for you in the auto. If you want a track car, you have the wrong car. But an MCS auto can be great fun on the street and the twisties.
Old 07-07-2008, 01:53 PM
agranger's Avatar
agranger
agranger is offline
You at least started in the right place... figuring out and writing down what you want out of the car and what you plan to do with it.
An air intake would be a nice intro mod that would let you hear more supercharger whine. There are also a lot of suspension mods that are well worth the time and $$$... I love my TSW springs, front camber plates and lower rear control arms (plus a good, agressive alignment). New wheels and tires (or just tires) would make a huge change, as would a rear swaybar, which you can do yourself fairly easily and is fairly inexpensive as mods go. Some less-dusty, more agressive brake pads were an early mod for me as I'm a big fan of adding 'stop' before you add 'go faster'.
A bigger, better intercooler would be helpful in AZ (as it is in TX) if you plan to drive your well-modded car on the track. At this point, it probably won't do anything for you other than suck your mod funds away from a more impact-ful place.
My basic mod-plan that I did on my '06 MCS manual that is my daily driver and occasional Auto-x and DE weekend car.
1. Hawk HPS brake pads
2. Lots of cosmetic mods... painted arches, shorty antenna, leather shift boots, etc.
3. Driveability mods... window tint, Driver's right leg pad (I hate the downtube after 30 minutes of driving), Whalen shift ****, etc.
4. Rear swaybar
5. Lower front strut brace and rear shock-tower brace
6. front camber plates, TSW springs, lower rear control arms and a good alignment
7. ditch the run-flats... get some nice sticky tires
8. Big Intercooler (only because I got a great deal on a used one... noticed absolutely no improvement at that time as it was my first engine mod... it might be doing something now)
9. Air intake
10. pulley / colder plugs / spark plug wires
11. exhaust
I've done a bunch of other things as well now... Big brake kit, stainless brake lines, brass bushings on the rear brake calipers, massive air-horn, etc, but that should get you started... :D
If I were to do it all over again, I'd probably follow a similar path and order to the mods.
Old 07-07-2008, 01:58 PM
Gil-galad's Avatar
Gil-galad
Gil-galad is offline
Proven fact. Experienced by many. The first mod is akin to eating that one Lays potato chip...except the impact to the bank account is a bit different.
Old 07-07-2008, 02:12 PM
mcs22004's Avatar
mcs22004
mcs22004 is offline
Happy Motoring.
- KP
You need to install a 6-speed or there is really no point in modding the drivetrain. After that mistake is fixed, a pulley will get you the most fun per dollar. Beyond that it is all downhill with regard to significant power increases for modest sums. A mere 250hp will probably run into the thousands. If you are willing to spend that there are plenty of threads to peruse on what it takes to get substantial power gains.
Old 07-07-2008, 02:50 PM
agranger's Avatar
agranger
agranger is offline
There is still plenty of fun in an auto. Personally I like the sporting feel of rowing the gears and executing a perfect heel-toe downshift, but you can tune it a bit for better handling, better braking and modest gains in power without ditching the auto or going too crazy in terms of cost.
The OP has his goal of making his daily driver a bit more fun... which is definately possible without switching to a stick. I've been on the track, being chased (and probably passed) by a nicely modded MCSa. He has less attention that he has to give to the transmission, meaning that he has more attention to give to hitting the right line and watching the corner workers ( :D - inside joke - sorry Mike! :D ).
Old 07-07-2008, 03:05 PM
BlimeyCabrio
I think the auto is perhaps the biggest reason TO mod the drivetrain... takes a 15% pulley to overcome the inherent inefficiencies of the automatic and make my car feel like a MINI, IMHO.
Old 07-07-2008, 03:20 PM
minihune's Avatar
minihune
minihune is offline
OVERDRIVE - Racing Champion
Happy Motoring.
- KP
You really don't have to do much and every upgrade has a pro and con with the change.
Pulley for the supercharger- usually a 15% reduction pulley is the best bang per buck and a good place to start.
Next is an RMW retune of the ECU for more power.
You can add a cool looking cold air intake if you like.
Exhaust systems are more cosmetic and usually costly unless you can find a used aftermarket one, or a single sided exhaust for less weight, or you can do a one ball- cut out one of the stock mufflers and reroute the pipe to one side like a bypass- this mostly saves weight.
Driving school is always the best upgrade in my book, check out what is available in your area from car clubs.
Suspension- some MCS owners upgrade to Koni FSD shocks just to improve ride comfort and handling.
Lighter wheels and non runflat tires- better handling and better comfort but depends on your tire selection. less weight is nice vs stock wheels and tires which are very heavy.
Upgraded brake pads that dust less and rear sway bar three hole 19mm is good, find a used one.
Plan before you buy and search for any of these topics, it's all been discussed before.
Old 07-08-2008, 09:05 AM
djflippy's Avatar
djflippy
djflippy is offline
Location: Orange County, home of the great and powerful Jan
I'm no expert, but I'm very happy with the performance mods I've done so far:
No run-flats
Pulley
Cold-air intake
Next up for me is a camshaft (already purchased), *maybe* a header, and definitely a tune from Revolution Mini Works. Then I'm done, for a while, honest...
Old 07-08-2008, 10:01 AM
blackX5's Avatar
blackX5
blackX5 is offline
KPMini - I too, have an Auto (MCS 06') This was suppose to be my daily driver (my V12 X5 is a gas guzzler) but I can tell you this much....you will SPEND$$ to get the most out of your auto mcs. My mods so far...Alta CAI, Alta Stealth exhaust, ver.2 Intercooler, 17% pulley and suspension galore (H&R coilovers, camber,...blah blah blah). And not to mention exterior upgrades.
Have I seen an improvement after the upgrades? Heck yeah....the fact that adding a new exhaust and CAI improved my gas a tiny bit and having the pulley just made the auto gear shifting so much more smoother. I'm in the talks right now with Jan about maximizing hp for an auto. Next up is a new header, and tune. thats gonna be under 2k at least. So yes my friend....you are going to spend and its worth every single penny cause this is the best....most fun car you will ever drive on the street.
Old 07-08-2008, 10:13 AM
ThumperMCS's Avatar
ThumperMCS
ThumperMCS is offline
Slightly off-topic...but you have a V12 X5??
Old 07-08-2008, 10:33 AM
blackX5's Avatar
blackX5
blackX5 is offline
Pardon me Thumper....a V8 315hp heavy tank. V12 is the 4.8i.
Old 07-08-2008, 10:42 AM
MINIGURU@WAY MOTOR WORKS's Avatar
MINIGURU@WAY MOTOR WORKS is offline
Vendor
Start with the Pulley, it's the biggest bang for your Buck.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old 07-08-2008, 12:41 PM
BlimeyCabrio
Notice Way didn't say "start and end with the pulley".
Hmmm.... suspicious....
Old 07-08-2008, 12:58 PM
checkers's Avatar
checkers
checkers is offline
I have one of those dreadded automatics and I love it. You asked about the W to A intercooler, I have had one on mine around 2 years and works just fine. As far as other mods, I have a few of them also, but mine not a daily driver. Just some weekends. To me it dosen't matter were you start your mods because they just keep coming anyway. It's hard to stop after you get started. Have fun and in joy it.
Old 07-08-2008, 01:16 PM
BlimeyCabrio
Originally Posted by checkers
To me it doesn't matter were you start your mods because they just keep coming anyway. It's hard to stop after you get started.
While logic screams that this shouldn't be true, experience shows that it mostly is.
Old 07-08-2008, 07:02 PM
MidnightDave's Avatar
MidnightDave
MidnightDave is offline
May I just say thanks to you guys for your constructive input and not just flaming him to use search?
We're all excited about our cars and want to anticipate and approach mods in the best way possible for our tastes, needs and budget, and appreciate the input and discussion.
Thanks, too for not just bashing the fact they left the third pedal off his car. I've seen Paul drive, from immediately behind, and believe me, off track, it's not much of a hindrance!
There's one more, really cheap mod that's mandatory if you're over 6' and do stop at red lights: a lightnsight.
Old 07-09-2008, 12:54 AM
groovetini's Avatar
groovetini
groovetini is offline
If more "go" is your game. then it's pulley, then intake/exahust. DONE.
Old 07-09-2008, 01:11 AM
Ju5tin's Avatar
Ju5tin
Ju5tin is offline
In terms of Intake, do you guys know where to start looking for these items rather than going through Mini directly? They charge an arm and a leg for the JCW parts.
Old 07-09-2008, 02:01 AM
british RACING green's Avatar
british RACING green is offline
I'd say with your auto trans. to go for the 17% (maybe 19%) pulley as you'll get more low end torque (and since it's an auto you won't be spending too much time near the redline, which is good). I think you'll get a more enjoyable driving experience.
-note: i dont have an auto but with everything i've read over the years this is what i'd do if i did have one
Quick Reply: Drivetrain Were to start Modding?
