Drivetrain Finally started our mini section
Old 07-13-2008 | 01:38 AM
Exhaust Depot's Avatar
Exhaust Depot
From: Orlando, my house is in fortlauderdale and im originally from da bronx
I started working on the mini section on our site. I still have to put up better pictures of the product etc but some prices with options are listed.
http://www.exhaustdepot.net/minicooper.html
Old 07-13-2008 | 05:47 AM
Bigjoeski08's Avatar
Bigjoeski08
Thats a awesome price for an turbo back exhaust I was just wondering could you guys make just a simple catback exhuast that doesn't require welding?
Old 07-13-2008 | 06:32 AM
jcap287's Avatar
jcap287
School away from MINI
its a cat-back. Is there alot of drone?
Old 07-13-2008 | 08:21 AM
ltjpunk7's Avatar
ltjpunk7
What is the price difference between aluminized and stainless?
Old 07-13-2008 | 12:56 PM
Exhaust Depot
I cant because I dont have the tooling to make this funky connection (left). Also if I did have it, i dont have the tooling to make that downpipe connection so close to a bend. I need atleast 3" of straight piping for my machine to grab on so it can make a flare. Regardless your looking at what a muffler shop will charge you to make one for you out of crush bent piping and its not flanged!
Old 07-13-2008 | 12:59 PM
Exhaust Depot
This is what I got from Jose, he posted it in the other thread. Remember, i can toss a resonator in there too, this is feedback for the 3".
"As far as I´ve driven, the de-catted version drones a bit at around 3,500 rpm. We have not heard any drone so far from the catted car. Also keep in mind that on the auto cars the rpm´s are lower than manuals at 6 gear cruising speeds so they will usually have less drone at highway speeds...specially at 75ish or so. "
Old 07-13-2008 | 01:02 PM
Exhaust Depot
The muffler and tip are stainless. Your looking at $150 as of now for polished stainless last time i checked. You would not believe how much stainless has gone up and steel in general! 4 months ago i paid $300 for a 4x8 sheet of 3/8 MILD steel. This month it cost me $288 for a 4x4! STAINLess 4x8 was $3000, im afraid to see what the sheet cost now !
Old 07-13-2008 | 01:12 PM
Creeve's Avatar
Creeve
The easy way to do it would be to flare the catback side to match the DP put a donut gasket in between and use a pair of two bolt flanges to keep it together.
Old 07-13-2008 | 01:16 PM
Exhaust Depot
That would work only if there was a flange on the end of the downpipe but there is not. Also i cant make a DP with a flare and flange on it because there is no material for me to grab with my tooling, i cant grab an actual bend.
Old 07-13-2008 | 01:25 PM
Creeve's Avatar
Creeve
Yea I can see that being a problem on a production level. What I did was cut a flange in half, weld two tabs on each side and bolt it back together around the DP.
Old 07-13-2008 | 01:36 PM
Exhaust Depot
IM always hitting my guys on the head when they making a production piece which they can easily do but the customer in another state cant.
Right after the *Smack, im rick james *****!* i follow with a "does the customer have a welder at their house?"
Old 07-13-2008 | 06:44 PM
Exhaust Depot
Here is the downpipe with out a cat. Ill be putting it up on the site tonight.
Old 07-13-2008 | 07:29 PM
Ryephile's Avatar
Ryephile
"resonator...requires removal of lower cross plate"
Are you referring to the black stamped steel structural brace that is fastened with 6 bolts across the exhaust tunnel?
Old 07-13-2008 | 07:57 PM
ThumperMCS's Avatar
ThumperMCS
That is a structural brace?
Hmm, I've been running without it for a while. I guess I should put it back on then....
Old 07-13-2008 | 09:22 PM
Exhaust Depot
That was entered in error. We have enough space to put a resonator with out having to remove the plate.That plate is not structual, it serves two purposes, provides less flex on a turn (like a strut tower bar) and on RWD vehicles, it prevents the car from flipping over if the drive shaft was to break at the trany.
Old 07-14-2008 | 04:17 AM
k@rtm@n's Avatar
k@rtm@n
What have you think about an O2 Sim for this downpipe???
HAve you a product that remove totally the problem of the CEL???
Old 07-14-2008 | 06:47 AM
Exhaust Depot
IM still working on a cel fix for the non catted setup. An o2 sim might work but I dont have the time to solder up bread boards.
Old 07-14-2008 | 01:24 PM
jcap287's Avatar
jcap287
So, what is the difference other than SS costs $150 more than the aluminium? Does the aluminium rust faster or is SS just purely for the shiny factor, etc? I'm thinking about about the 3in. Cat-back. Whe at will happen if I cut off the second CAT will I blow cels or anything?
Old 07-14-2008 | 02:26 PM
Ryephile's Avatar
Ryephile
Stainless has noticably better thermal characteristics, in that exhaust heat-energy stays within the exhaust pipe more than mild steel instead of radiating out the walls into the car/engine bay/exhaust tunnel. There's a reason Formula 1 cars run Inconnel, which is basically a special version of stainless steel. Stainless will also last much longer than a mild steel setup, even one that is aluminized. All factory car exhausts that I can think of are at least 409 stainless steel, including the MINI. Going to a mild steel setup is certainly valid in terms of being value-concious, however you will want to avoid driving in the rust-belt states!
...That plate is not structual, it serves two purposes, provides less flex on a turn (like a strut tower bar) ...
So by less flex, you mean to say it is a structural brace?
Old 07-14-2008 | 03:14 PM
jcap287's Avatar
jcap287
Ic. I'm debating between this (in SS) and the alta one. I have the money for either + install
Old 07-14-2008 | 04:26 PM
Exhaust Depot
Aluminized steel is mild steel dipped in aluminum. It sounds better than stainless and has less of a tingy sound. Stainless is at a higher risk of cracking because it has a higher expansion rate. 321 stainless and inconel however have less of a tendency to expand like 304.
Most exhaust systems have aluminized mufflers.
Old 07-14-2008 | 04:28 PM
Exhaust Depot
For me structural is something that is part of the frame like a beam in your house. Your car wont come apart on a turn with out a brace etc, your house will come apart with a beam missing.
Old 07-14-2008 | 05:38 PM
KyleJ's Avatar
KyleJ
Just curious when a full turbo-back system's pricing is going to be available.
Old 07-14-2008 | 06:12 PM
Exhaust Depot
TOnight or by the latest tomorrow.
Old 07-15-2008 | 02:39 AM
jcap287's Avatar
jcap287
General question. If I cut off the second will I still beable to pass emissions and inspection? Off to work though talk to everyone later.
Quick Reply: Drivetrain Finally started our mini section
