after much thought i would like to leave my ecu/pnp under the hood.my clubman only has 3000mi so i want easy removal for service. there is some space by the washer fluid reservior up front under the brace. i did a test run and it will zip-tie in real nice, but the rain/moisture scares me. any thought on waterproofing or any ideas? thanks
since the car is new(3000mi), i would not want to invalidate any warranty. the service advisor has let me install a new intercooler, cai, and silicone tubes so far.. the pnp from alta/m7 sent him into a cold sweat. so i figure what he does not know wont hurt him.
i dont think you understand.. the system plugs into the ecu and the original harness "piggybacks" the top of the pnp unit. when i meant remove it for service i mean TOTALLY REMOVING the harness as well so there are no traces that a chip was ever there. im just trying to weatherproof the connections to the chip as well as the chip and map button.
OK, now I understand what you are trying to accomplish. A little risky, but I see that Alta has done some tests to "guarantee" its success. I would weatherproof it by applying heatshrink tape to the body of it, and sealing off the cable entries with silicon.
