Drivetrain m7 heat shield installed
#76
#78
#83
On August 12 I placed an order with my local aftermarket parts dealer, Bishop Sales (www.bishopsales.com) for the AGS-R, intercooler bezel, cross bar, charge pipe and sway bar. So far nothing has arrived, although I am told my order will be shipped soon. Needless to say, I am very !! Part of the price I pay for living in the "true North strong and free" I guess.
#84
hahaha well that is quite an order! I'm going to order one probably later today after class finishes. I have a lot of paint going on the car so its going to look nice when its finished...i got the vortex and the m7 strut brace. Vortex is the process of paint now..body color. But WoW, over a month, I feel your pain!! Once its on, you will forget all that tho...hahaha
#85
Let me know how you like that Vortex. Body colour is a good choice, as the scoop will be dramatic enough without a contracting colour. I haven't yet decided how I'm going to get in the extra air I'll need.......
#87
Awesome, do post when you get the peices on! Oh and can you snap a picture of the gel coat on the AGS-R!?! I want to see if I even have to paint it at all.
Update from me...I got the AGS-R today, will come in either next Tuesday or Weds. My scoop and trim pieces will be finished by tomorrow morning, can't wait!
#89
#90
My heat shield was the earlier version and was contacting my hood so I decided to modify it myself. I don't particularly care for the latest design. I made the hole bigger for the O2 sensor made a slit on lower section, rounded the corners and bent it out some where it contacted the down pipe heat shield. I then put a semicircular notch on the right side where the turbo lubrication pipe is and on the same side at the bottom I cut off the corner where it came in contact with a bolt head. I painted it with rust-oleum high heat paint, it's a very flat finish. I may redo the paint with some high temp automotive semi-gloss. These changes allowed me to push the heat shield back 3/8 to 1/2 inch more than before. I did some aggressive starts so the engine would torque over and so far it isn't contacting the hood.
#91
on
#92
#93
#94
#95
thats what I'm hoping with the new updated version! lol It's hard to account for engine movement and torque under the hood while driving. I agree, you shouldn't have too, and 200 seems a bit high anyways, but it does a great help to your engine bay eliminating a good deal of heat soak. However, you can return the shield and m7 will get you a new one, but why do that if simple modding diy style works just as well? It's preference in that method.
Many people mod their mods, I know I do.
#96
on
I have heard good things on the latest revision and I believe the problem to be solved. Let me know if I can help or if you want me to strong arm m7!
#97
In my opinion for what it is worth, I do not think any vendor should be commenting on manufacturing turn around times. What goes around comes around. I know Peter and when the problem was brought to their attention, action was taken. Prototypes worked well in the handful of mini's tested. However, each mini has its own set of tolerances and what fits one, may not fit another so well. Once in manufacturing, you are the mercy of the manufacturing company and things will change (like it or not). Peter and company can not do a handful of repairs and be expected to keep the costs low. The changes once introduced has to be done in a quantity run and you have to wait for the company to do its things. As I said, just my opinion and from someone that has many years of experience in manufacturing of products.
#98
on
I just had Peter up here in Oregon last Friday. We are WAY good! He and his staff have been working with my staff on strategy to resolve this. They even released a new version to help better fit with my downpipes.
I honestly was trying to make light of it not come off like a turkey! Like I said, "we all make mistakes" I am including myself in that boat.
Hope that helps clarify! Chat soon!
#99
on
Nice work 2008lightening. These sound like some of the mods I am going to do to my shield too. I am also thinking about changing where it bolts to the engine by using the two blank bolt holes that are available. I wasn't too thrilled with removing the two bolts which hold the stock heat shield in place. I checked after bolting in the M7 and the stock heat shield was not securely fastened with the two long bolts that hold the M7 in place.
I agree. I am seriously thinking about creating new holes on the shield to mount via the preexisting holes. I am not entirely sure why they did not use them. I will post pictures.
#100
You would be better off replacing the bolts with threaded studs of the equal length, running a stainless washer and nut all the way down to secure the heat shield to the stud/bolt and then placing the shield on and capping it with a stainless acorn nut. Now you have the stock shield secure and the new just as secure without having to drill new holes or worry about other problems.
Hope that helps.
