Drivetrain Is my exhaust leaking?
I went to look at my car at the shop today while all it's goodies are being fitted on.
I noticed on only the rear half section of the exhaust system that there is some black soot. Do you think it is leaking from this bracket? I asked the mechanic and he says it's normal, but then it should be on the entire exhaust and not just the rear half?
![](http://img401.imageshack.us/img401/6986/img00065oi4.jpg)
Also notice where it splits to the 2 mufflers. Only the one side has the black soot, I think it may be leaking from the weld?
![](http://img262.imageshack.us/img262/4331/img00064ud0.jpg)
There is a slight leak. Water will mix with the exhaust soot in the pipe and leak out when the exhaust is cold. If it is a small leak, it will seal up when the exhaust gets hot and the metal expands. It normally is not a problem. Only a problem if there is a big leak that will not seal when hot. From your pictures, yours looks normal.
gmonde
09-08-2015 06:37 AM
