Drivetrain Difference in crankshafts
I believe all of the other factors (journal sizes, flywheel bolt pattern, harmonic balancer shaft sizes) are the same, but since the S engine (forged crank) has forged rods instead of the powdered metal standard rods, there might be a difference in balancing. A forged crank is heavier than an equal-sized cast crank, so the bobweights (counterbalance) are heavier than cast bobweights of the same size.
typicaly, a crank, stripped of all rods, is balanced by bolting weights on each rod journal equal to a percentage of the conrod weight. it is then spun and the counterweights ground to balance the shaft radially and axially. Sometimes the harmonic balancer and flywheel are included, sometimes they are independently neutrally balanced (usually better)
patsum
26
05-29-2021 06:29 PM
larryd96
11
09-08-2015 05:01 AM
