I have on order the Alta intake/boost/inlet tube. What are guys thinking I should expect in a hp increase? I already have the Evotech tune if that makes a difference.
perhaps quicker throttle response. doubt you get alot of HP.
actually once i installed the alta intake i had a noticable decrease in throttle response in the lower revs (under 2500). but the mid to upper revs were stronger and its sounds amazing.
Once an ECU Solution becomes available (Besides the JCW One) and you raise boost a bit the parts you ordered will help. So eventually it will not be a waist of money.
Do a search and you will find a guy who dynod the Catback, Intake, and Boost tubes and got 4 or 5 HP
I already have the "new" Evotech ECU custom tune (the same one that Mini Madness is selling) that I had custom tuned on a dyno. I will probably have them install the new peices and see if a new tune is needed. If so I might do a dyno before and after again to see what the intake system does..
