the mass air flow is to small only 2.5 inch needs to be 2.75 at least for better flow ,testing some softwares right now its looking good so far
The software must be tuned for the MAF diameter like Hector says. Very important. You need to confirm this with your tuner, not just play with the size. It makes a large difference.
Exhaust Depot's response was the professional's way of calling bull****! It is odd that you have installed something nobody has done before but you can't take apart a simple sensor. I find it hard to believe that someone with supposedly significant technical knowledge believes that simply altering the size of a sensor will magically tie together your modified system.
I put mine in the cold air intake and let some of the air bypass it. runs sometimes a bit rough but lets in more air without recalibration. they do it on the WRX and other cars.
Where can I find my MAF sensor? I have an 03S w/98k on it and it gave me the SES light on my way home from work. The code was P0171 - running lean. I have read that cleaning the MAF sometimes helps, but where is it?
Where are these sensors? I am thinking that I paid for some bad gasoline (at least that's what the mechanic down the road propositioned) The autoparts manager at OReilly's said to put Lucas in the fuel and run it until it is almost empty then go somewhere else for gas.
Still, I need to know what I can do with a p0171 code and will it hurt if I continue driving it until replacement parts get to me? I took the day off thinking I would end up too far from home.
