Drivetrain R56 custom tuning by RMW
#301
#302
#303
The unichip gave my 07 S awesome power but it also gave me tons of CELs (until I finally got a good harness) and occasional engine "super knock" from having either boost too high or timing too advanced for the 92 octane gas we have here. I didn't make up the term "super knock" either. It was printed on the diagnostic sheets the MINI techs would print out each time I came in for service. "Super Knock" does not cause a CEL but it will store a fault in the ECU.
My JCW with the DIMSPORT mild blind tune (meaning the tuner didn't want to push anything very far since we weren't on a dyno and I haven't installed a boost gauge) has more butt dyno power than my 07 with the unichip. At the same time I feel confident it is "safe".
for giggles my 07 S dynoed 203hp and 237 lbs torque atw with the unichip.
#304
Sure Richi's post was directed at me....but your answer is thorough and accurate.
MotorMouth is correct.....16.5psi is the target boost level mine is set at. Generally this only occurs during overboost, where I'll see 16-17psi depending on a variety of factors. Most of the time in non-beat on the car mode...I'm seeing about 15ish psi.
And I'm going to go on a limb and say that the UniChip might infact give better peak numbers...so if thats what you're excited about thats the ticket. However, a dyno tune is going to yield a much broader torque curve and gains across the board...all while being suited to your car to ensure that maximum safety limits are observed.
#305
#306
#307
I am asking because it seems awkward for a tune to make more horsepower on lower boost levels/not as an advanced timing. Of course a/f is a main factor but can be adjusted by both tunes. For the last 2 posts, I dunno, without the unichip I was peaking at 15 and sometimes almost 16. Did you get an update on your software?
#308
The unichip was definitely running more boost than Jan's tune. The big difference is Jan wants to stay in a safe zone. The other difference is Jan can tweak the timing and AF to each individual car where the unichip was a canned tune. With tweaking you can get the max SAFE power.
MM, what type of dyno was used for the 07 S? Was the a/f probe at the tail pipe?
Thank you,
Don
#309
It was on a Dynojet and AF was measured with a tailpipe sniffer which is known not to be very accurate due to the catalytic converters.
I have sourced a new dyno that takes the reading from the O2 sensor. When I get the time to dyno tune the JCW (and time to install my boost gauge before teh dyno tune) I'll use this one.
A friends 07 S was dyno tuned on it (using dimsport) and his A/F stayed below 13:1 in the full rpm range but he didn't have a boost gauge so the tuner didn't push the boost too far. He ended up with 217lbs torque ATW. The friend has installed a boost gauge since then and it shows him peaking ~15 lbs boost.
#311
#312
'07's that haven't been to the dealership for updates will see ~15.5PSIg
'08's will see ~12PSIg
'08 w/ JCW Stage 1's will see ~14PSIg
^^^That's all "Overboost". Normal boost is a paltry 8.5-ish PSIg. YMMV depending on climate and mods.
The MCS's all taper to about 8PSIg at 6500 RPM, whereas the JCW Stage 1 tapers to 9PSIg at redline.
#313
#318
#321
Stir all you want, nice to see you have a revision.
A dyno sheet with A/F would be the proof most of us are waiting/wanting to see.
Not one of those wimpy, you can barely read dyno pictures, either.
Jan, how goes the reflash tool and the R56 power curves? I'm up to about 8 in Denver that are interested, 5 or 6 R56 variants.
Don
Don
#322
this was just driveability........ since Thumpers car had a DDM intake the maf was interpreting some things differently....... smooth as butter now
working on flash tool for the R56.......... I'll call and see where we care on it
My son is graduating this weekend so no dynoing till next week
Don
Don
